Fuel Gauge problems
Discussion in '2005 - 2009 Specific Tech' started by iskwezm, Jun 22, 2006.
  1. iskwezm Well-Known Member
    May 24, 2005
    Message Count:
    3,944
    56
    In the morning or when the car is cold and i floor it, the fuel guage will drop to "E" and stay there for a while, ususally when there is a 1/4 tank or less. Anybody else have this problem??????????:shrug:
  2. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    some common suggestions:
    use chevron gasoline, or use a techron additive to your tank.
    keep your tank full. :)
  3. iskwezm Well-Known Member
    May 24, 2005
    Message Count:
    3,944
    56
    :shrug:
    Was that a serious answer????????
    I need a fuel additive for a 6 week old car?????
  4. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    yes, techron additive helps. it has been around for a while with corvettes. if it does it often, i would take it in, if it does not do it again, dont worry about it.
  5. Infinity Founding Member
    Apr 7, 2002
    Message Count:
    1,250
    Mine tends to stay on E because I can't afford to fill it up anymore :banghead:
    :D
  6. iskwezm Well-Known Member
    May 24, 2005
    Message Count:
    3,944
    56
    Im thinking it has a bad pump/sender, but it also probably electrical, because it only happens when its cold and i run it through the gears, it will read "0" miles to empty, no matter how many gallons are left
  7. Pliskin New Member
    Jul 27, 2004
    Message Count:
    131
    Use the techron additive. If you go to your dealer they could give your some for free through warranty. If not, don't use cheap gas with high sulfur ratings. Im sure your car doesn't like it...and now you're not.
    But yeah, if you run a few tanks of the techron (chevron gas) through and it STILL does it, then yes you have an issue. But most likely its the sulfur content messing up the readings in the tanks. From what I know its from when Ford switched to the saddle bag type gas tanks and how the units measure the gas...being coated in the sulfur it gets a bad reading. So get that techron in there all nice and covered like and you SHOULD be fine.
    Now thats what you have to worry about if you can actually afford gas for this thing...I sure as hell can't. Haha.
  8. killertomato New Member
    Jun 12, 2006
    Message Count:
    31
    Also have this issue
    I also have come across this issue with my two week old 06 GT. It does seem to happen after sitting for awhile and then being ran "vigorusly". I've been using BP:bs: gas whih is recomended on the gas cap :) On the third strike shes going in for service.
  9. iskwezm Well-Known Member
    May 24, 2005
    Message Count:
    3,944
    56
    let me know what happens
  10. forfun Banned
    Apr 22, 2002
    Message Count:
    211
    Try getting a new guage!
  11. anthony05gt New Member
    Mar 19, 2006
    Message Count:
    1,268
    The gauge is part of the cluster assy. That probably is not the problem. Like bigcat said, try a bottle of techron.
  12. 5stangs New Member
    Jun 17, 2006
    Message Count:
    Mine does this from time to time, but mostly when I'm turning a corner fast and only shortly after start up..
    I seems like it takes a few minutes for the tank sensor to realize exactly where it's at. Also the sensor must just be more sensitive to sloshing in a near low tank.
    I can't say I would worry about it much.
    Matt-
  13. killertomato New Member
    Jun 12, 2006
    Message Count:
    31
    2 Bottles of Chevron later and 3-4 tanks of gas since and I've had no further gauge issues. I suspect it wasn't the gas I'm putting in but the gas that WAS in it when I bought the car a few weeks ago. No issue at all since the addative though.
  14. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
Share This Page
