Fuel Pump? Maybe?
Discussion in '1994 - 1995 Specific Tech' started by Dan Ford, Jul 7, 2013.
  1. Ok, for a while now I've been noticing a high pitched whine coming from the fuel pump of my 1995 stang. I know that usually means its about to go out ,right? So the last few days its been taking forever to start and when it does it is not roaring to life as usual,rather sputtering to life. After that it would idle out and run fine,until today. Today I drove it about 40 miles to visit family. On the way down everything was fine. On the way back as I shifted through the gears I knew somthing was'nt right. It ran fine until the tach reached 2000 rpm then it would just choke down.the more throttle I gave it the more it would bog.
    So my question is ,does this sound like a fuel pump going out or is this a whole new PIA altogether?
  2. Check your fuel pressure. But yeah, it sounds like it's time for a nice upgraded Walbro.
    k00ksta likes this.
  3. That could definately be a fuel pump. If you have any means of checking your fuel pressure, that is the way to go.
    Kut
  4. Thanks for the reply's. I hope it is thje fuel pump,I hate having to chase problems around. Which seems to be quite often with this car.
  5. The mustang doesn't like to run with a dry tank. So when you get a new one in make sure to keep her topped off.
  6. I have heard that. Never really understood it,but have heard it. If thats true then I guess I killed it,cause I love to run on the E.
  7. Yeah, the pumps don't survive when ran dry.
