I am wiring in my fuel pump and found that the yellow wire in the fuel pump harness (at the pump) provides power when the ignition is switched on. It only provides 7.88 volts (not a result of a bad ground). Does anyone know where this wire traces back to and where the step down in voltage occurs?
Remember... I have removed the CCRM and PCM completely and am only looking to provide twelve volts to the yellow wire (at the pump) keeping the inertia switch intact.
Thanks for the help!
