Yes, drop the entire pump. There are 3 or 4 bolts that hold it in place. I think you have to move part of the wire harness or something out of the way to get to the bolts.98blackstallion said:Guys help I cant get the damn power steering pully off the f'n pump what the hell am I supposed to do? Should I just drop the pump and leave the pulley on or what please help me!??
yup did the sameBlev said:Yes, drop the entire pump. There are 3 or 4 bolts that hold it in place. I think you have to move part of the wire harness or something out of the way to get to the bolts.
Why are you dropping your oil pan? If you're talking about the bottom bolt from the timing cover that goes into the oil pan then get a set of those vice grip plyers, can't remember what they are called exactly, sorry. Then clamp them down REAL tite and there ya go. Otherwise you can pick up a socket from sears that's made to remove striped bolts.98blackstallion said:Well everything is going really well EXCEPT now i have got a stripped oil pan bolt! I have some really crappy luck when it comes to cars lol....Whats good way to fix this problem?
98blackstallion said:anyone know the part number for the dipstick that comes in the ford head swap kit because mine just f'n broke and i have to get a new one now...i just love fords so much it hurts...
98blackstallion said:yep ive come to the conclusion that i will drop the exhaust manifold and also have to remove the motor mount to access those bolts i need to loosen so I think i should have just pulled the motor instead of leaving it in the car.
