got gears
Discussion in '94-95 Talk' started by OrangeMustangGt, Nov 15, 2006.
  1. OrangeMustangGt Founding Member
    Mar 8, 2002
    Message Count:
    1,985
    36
    i finally got my 3:73's switched out to 3:27's....and wow does this car pull hard now in 1st and 2nd....like a kick in the back.
    All it needed was some load.
    Plus now its a cruise-o-matic as far as rpms and shifting!
  2. urban96 bubb rubb says:"woo woooooo"
    Sep 25, 2002
    Message Count:
    4,233
    66
    shoulda got 2.73's
  3. 1TallMF New Member
    Apr 18, 2006
    Message Count:
    971
    3.73's ---> 3.27's = better pull :scratch:
    This goes against everything I believed.... please elaborate :shrug:
  4. The Green GT No 13 year olds are safe around me.
    Jan 8, 2006
    Message Count:
    3,438
    68
    :stupid:
  5. SeventyMach1 Keep it lubed .... keep it straight .... and keep
    Mar 31, 2005
    Message Count:
    1,972
    36
  6. The Green GT No 13 year olds are safe around me.
    Jan 8, 2006
    Message Count:
    3,438
    68
    So boosted cars pull harder with lower gears?
  7. SeventyMach1 Keep it lubed .... keep it straight .... and keep
    Mar 31, 2005
    Message Count:
    1,972
    36
    Actually, he went to a higher gear.
    I think some boosted cars need a higher gear in order to get the car to shift (and feel right) at the optimum power range. Something along those lines.
  8. urban96 bubb rubb says:"woo woooooo"
    Sep 25, 2002
    Message Count:
    4,233
    66
    well hes got a turbo and itll build more boost with more of a load
    i htink :shrug:
  9. greenstang1313 New Member
    Jun 15, 2005
    Message Count:
    159
    first gear is useless with any more than like 250rwhp when you have tall gears, this guy is probably pushing over 400 (just a guess) so do the math, some 3.27s would be much better for driveability.
  10. trav_19 New Member
    Oct 29, 2006
    Message Count:
    844
    :shrug: :crazy: :banana: im totally lost i got an automatic so everyone sugest using 4:10 but im putting nos on it do i lower gears and probley some time next year maybe in the winter i will be swaping the nos for a supercharger? so what gears should i buy now?:shrug:
  11. urban96 bubb rubb says:"woo woooooo"
    Sep 25, 2002
    Message Count:
    4,233
    66
    turbo is a whole diff ball game
  12. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    Several things you need to consider about different gear ratios and the application you use them for.
    As said above ... na and pa makes things VERY different
    Also a na stock or bolt on Stang acts differently
    as opposed to
    A na Stang with h/c/i for two main reasons
    1) the power band has been shifted up
    2) the power band has been extended
    If you're gonna have a quick na stick trans Stang that works half way decent when you take it to the strip
    The following needs NOT to be at the top of your concerns list
    1) first gear traction when driving on the street
    2) first gear being too short
    3) highway cruise rpm's being too high
    The things listed above and more might cause you to see that there may come to be a point in your Stang's life when ............
    you start to see you need a beater to get around in so things like we talked about above don't cause you to have compromise your performance goals due to your Stang is your only mode of transportation.
    Bottom line on gear ratios is ........
    its the application that dictates the ratio :)
    Perfect example is as above with Kyle ...........
    A guy with a turbo will generally want a lower (numerically) ratio
    than
    A guy with a na h/c/i combo that does the weekend 1320 thing
    Grady
  13. ProKiller Founding Member
    Apr 26, 2002
    Message Count:
    2,865
    58
    i've thought about putting my stock 3.08s back in my mine to have this same effect...
  14. OrangeMustangGt Founding Member
    Mar 8, 2002
    Message Count:
    1,985
    36
    whell, my 3:73's were great when i was n/a....i was very happy, BUT with turbos its a whole different game. Turbos are load dependant as they use the exiting exhaust to spool. With my 3:73's first gear was so short that it wasent putting a full load on the car, so it wouldent build much boost, then when i hit second it would pull twice as hard as 1st gear, and usually just blow the tires off on the upshift.
    Now, 1st gear is like it should, it pulls very hard, and 2nd gear pulls even harder then before....it builds full boost in the gear because it has load. What made me realize that i wasent getting my full potential was when i got into the throttle going up a hill....it hit full boost almost instantly and kicked sideways in 2nd at around 3,000-4,000 rpm.....something it wouldent do on flat ground. Now it just peels tires as i roll into the boost at around 3000-4000 rpm in 2nd on level ground!
    as an added bonus, i get to cruise much better as i daily drive my car, and less shifting. Ohh am i happy, and once again let me add that i love turbos.
  15. mo_dingo New Member
    Aug 27, 2003
    Message Count:
    3,031
    As said before, the turbos widen the torque band, thus is is better to have smaller (numerically) gears because the longer you can stay in your powerband, the better.
    Since a stock mustang has a very narrow powerband, bigger (numerically) gears allow you to use all 4 gears and stay in the narrow torque band.
    Tractive effort FTW!!!!
  16. Zero Signal Active Member
    Feb 24, 2003
    Message Count:
    2,644
    36
    :Word:
    And of course as mentioned above, keeping it in the lower gear longer keeps the turbos spooled properly. Busting through gears really fast while lifting the throttle to shift kills the constant load.
  17. 95five-oh New Member
    Jun 26, 2006
    Message Count:
    159
    what ratio would be the best of both worlds for a bolt on n/a car? good acceleation yet liveable on the highway? 3.08's make the car seem so droopy.
  18. SeventyMach1 Keep it lubed .... keep it straight .... and keep
    Mar 31, 2005
    Message Count:
    1,972
    36
    There really can't be a "best of both worlds" here.
    But 3.27's are right there in the middle of your average N/A and FI setups.
  19. OrangeMustangGt Founding Member
    Mar 8, 2002
    Message Count:
    1,985
    36
    i vote 3:55's for a na combo....they are very good still on the highway but is as far as i would want to go....although i did have 3:73s that i was happy with, but i have no problem going 70 on the highway....many people want to go faster.
  20. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,794
    76
    You and I think alike. I have 3.55's in the '94 and very-much like them. I however am not a fan of numerically large gears.
    I had a turbocharged Porsche and the gearing was numerically low and it was wonderful. Boost came on very early and I had enough gear to keep it spooled. I did some tinkering and the A/R was not optimal for the set-up, but under acceleration it could still pull stool right out of your colon. :D
    Enjoy!
Share This Page
