GT40 intake install question
Discussion in '94-95 Tech' started by smilts, Feb 9, 2012.
  1. smilts Member
    Jun 18, 2011
    Message Count:
    79
    Ive probably missed it somewhere. But I'm trying to figure out how to run the vac lines on my new intake. Seems theres way more vac ports on it than I have lines to go to it, not sure which is which. a picture would be great. Im using a PP adapter elbow with my stock throttlbody on it, if that helps. If someone could link me to pictures that would help a ton. Thnx
  2. Venom351R Founding Member
    Apr 27, 2002
    Message Count:
    13,725
    9
    88
    MAINE
    There should be one vac line. All of the intakes Ive ever had most of those holes were capped off except for the vac line.
  3. smilts Member
    Jun 18, 2011
    Message Count:
    79
    My OE intake had one line going in. and 2 lines connected coming out going to the PCV? Im not sure which vac ports to use for these lines? Also the adapter elbow doesnt have the small vac tree coming off it like the old intake. The fuel pressure regulator and EGR vac were connected there on the old intake?
  4. Rick 91GT StangNet Sponsor
    Mar 9, 2001
    Message Count:
    9,175
    24
    98
    PA
    Does it have a tree on the bottom like this picture? If not you can transfer your stock one over.
    [IMG]
    Personally I run the Brake booster line to the underside of the plenum, then run the PCV off its own line to the center port under the intake, I use a small tree or nipple off the TB flange to run FPR, then use the underside tree for the other vac accessories.
  5. smilts Member
    Jun 18, 2011
    Message Count:
    79
    Thank you I think that picture will get me what I need. it has 2 trees off the center of the plenum. I believe I can take the small tree off the old intakeand put it on hte elbow adapter for the EGR and FPR.
Share This Page
