- Nov 27, 2001
- 89
- 0
- 0
Help, Car stalled and won't start
Sorry for the long post i tried to make it as detailed as I could
This is the 2nd time it happened to me and now it won't even crank over. Tuesday my car sputtered a bit when going from a complete stop and about 3 blocks later when i stopped at a red light (thankfully off a residential street) when light turned green I tried to go and car just stalled. I pushed it off to side and tried to restart it and nothing. It would crank properly for a few seconds and then stop kinda of like a dead battery (battery should be fine, its about a year old with no leaks or anything and the voltage is fine)
Well after sitting there for an hour trying to crank it over every once and a while it finally started up but the moment i put it in first gear and tried to go stalled out again, cranked it over and it started up again first time and i just decided to let it idle for a while longer to see if any help, pretty rough idle but next time i went i put a bit more gas while in first and it went without a prob. Took it directly to mechanic who did a Scan, checked fuel pressure and whatever else he could do. There were no codes stores, fuel pressure was normal but when I was leaving i noticed that at about 3.5k-4k RPM the car would stalled out there powerwise it would not go past it and exhaust would pop.
Yesterday, got gas, started going to a friends house, i felt it kinda buck/stall out on the way there and immediatly I was like Stopped at a T-Stop started to take a left, bang, car stalled. I pushed it off to side of road again tried to start and nothing and it didn't start again after that. It will crank over a few times and then stop, sometimes will crank only once, maybe not even at all, sometimes it can crank for a while. It sounds like it's cranking and then something just grabs it and stops. I can hear the fuel pump priming everytime but i'm guessing it's dying not sure though. any help?
I don't think it's any of the grounds, i check them often (though it could be the engine block ground which is hard to check at times)
Car is a 5.0 Cobra 5speed, stock for most part (just small things like filter, performance distributor livewire kit, MSD Dizzy (stock one's pip went out), fuel filter was changed about 8k ago
Edit: just remembered never put in the performance dist Dyna Mod, just slipped my mind and then my mom misplaced it. Could the stock one be shot?
