i tried to start my car today and it wont start.. i relocated my msd the day before and every thing is hooked up right.. and my flex fans always came on with the ignition and now the dont ?????
Ryan91Saleen said:the engine will turn but it wont fire the relay thing thats by the battery has power and all my msd stuff is hooked up i put the msd + wire to the relay. QUOTE]
if the motor turns over at all (just turns, not necessarily start), this "relay thing," aka, starter solenoid, has to be working. the only time the solenoid can realistically be thought at fault, is if nothing happens when trying to start, and other systems and tests reveal the solenoid to be at fault.
i would recheck your ignition box wiring, and as someone (Chetly?) suggested, there are fusable links for the ignition and you should have done something for the fan (links, and/or a fuse), etc.
good luck.
NKau said:Did you check for spark? Pull a plug wire off and put a spark plug in it. Then have somebody crank over the engine while you watch the plug tip to see if there's spark. If not, the most commone cause of this seems to be the TFI module (the thing bolted to the front of the distributor). You need a special TFI removal tool that any parts place will have if it the TFI turns out to be your problem.
im not sure that anyone can help you much, as we dont know exactly how you wired your fans in. are you saying you used the maf as a trigger for the relay for the fans? ah, i would not have done that. if not, my bad, i just dont get it.Ryan91Saleen said:also is that why my flex fans dont work they always come on with the key and not they dont.. the fuse link looks a brown and crusty like it got burnt. i put new wire in and they still dont work could the fans be blown?
