Help me decide on a SB
Discussion in 'SN95 4.6 Talk' started by darkside03gt, Jan 8, 2009.
What SB should I go with?
MMR 7 vote(s) 46.7%
Foxlake 1 vote(s) 6.7%
MPH 4 vote(s) 26.7%
Livernoise 3 vote(s) 20.0%
  1. 02LaserRed2V New Member
    Jul 31, 2004
    Message Count:
    399
    Augusta, GA
    gotta disagree with ya there. They've done work on both my cars and they run like a dream.
  2. 98stangv8 New Member
    Oct 4, 2003
    Message Count:
    1,059
    fayetteville, nc
    I just wouldn't go with MPH...so Foxlake is the one remaining..
  3. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,644
    36
    UCSD/La Jolla
    I hear and understand ya man. MMR isn't doing my build, they are balancing my rotating assembly and supplying me with side bolts, and possibly still might bore my block over. All of which because they are close and can send down my stuff when they have a shipment already being sent down here. They ported a set of PI heads for me, which i did have complaints about concerning the seat pressure and valve height, but they were very willing and happy to fix any problems i pointed out. In the end the problems shouldnt have been there as they knew what cams i was running (looked to even be off if i were to run stock Pi cams) and it cost me money to have a local shop figure out what was off about them.
    So it's not like im singing their praises. I'm just saying parts are parts. I know i didn't buy any MMR parts besides side main bolts, i acquired everything myself, and will build it myself. So it's more of a CobraRed shortblock than anything else.
  4. darkside03gt Member
    Feb 20, 2007
    Message Count:
    887
    18
    Sacramento CA
    I would assemble my own SB but I am unsure of the process and not very comfortable with it due to all of the clearances. I am to worried that I would screw something up and end up with a $2000 boat anchor. I am however confident that I can assemble the rest of the engine and istall it myself. How did you find out your seat pressures were off?
  5. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,644
    36
    UCSD/La Jolla
    I'll have help from someone who has done it before quite a few times. As for the seat pressure, since i'd had so much trouble with heads before that point i had Total Performance look over my parts before they go in. They sighted the problems i'd face when putting the cams on. Noticed the stuff was off, but had to figure out why. I believe it's becaue MMR sinks the valves seats a bit into the head when porting for more flow. But that changes the height and pressure which maybe they dont address. i've been telling people to talk to MMR about that before ordering to make sure it's a-ok with their cams and springs.
  6. darkside03gt Member
    Feb 20, 2007
    Message Count:
    887
    18
    Sacramento CA
    I would do pretty much the same thing you are if I had someone to guide me through the process. I also know I could save myself some money in the process. I am hopeing that I can make a little cash off the current engine when I pull it to buy you guessed it more parts.
Share This Page
