B bmk000 Founding Member Nov 12, 2001 102 1 0 Aug 26, 2003 #1 Aug 26, 2003 #1 I Will Have All The Other Bolt Ons But Need To Figure Out Which Cam To Run With These Heads And Intake Combo
D D347643 Banned Jan 28, 2003 1,095 0 0 portland, OR Aug 26, 2003 #2 Aug 26, 2003 #2 if i was you i would get a steeda #18 or a trick flow stage 1 cam. Unless you have 250 bucks to spend on a custom cam. Drew
9 92GreenGT PEAT Founding Member Jul 18, 2002 2,085 1 46 37 Big Stone Gap, VA www.fullthrottleforums.com Aug 26, 2003 #3 Aug 26, 2003 #3 Get a N-41 from AFM. Dave
B bmk000 Founding Member Nov 12, 2001 102 1 0 Dec 24, 2003 #4 Dec 24, 2003 #4 where can you buy and look at afm cams Reactions: 1 user
DemonGT Founding Member May 24, 2002 862 49 49 Sparta,WI Dec 24, 2003 #5 Dec 24, 2003 #5 i beleave the TFS stage 2 cam was made to go with those heads and intake
speedracer238 New Member Sep 18, 2003 141 0 0 40 Clawson, MI Dec 25, 2003 #6 Dec 25, 2003 #6 Stay with Trick Flow I would stick with the TFS Stage 1 or Stage 2 since those cams were made for that combo. And you can't beat the $140 pricetag from Summit
matty50racer Founding Member Nov 8, 2002 242 0 16 39 Pennsylvania Dec 25, 2003 #7 Dec 25, 2003 #7 Custom Comp TFS stage 1 and steeda #18 are too small. TFS stage 2 is good if you are on a tight budget.
TT91 Active Member May 23, 2003 1,536 0 36 41 Paramus, NJ members.rankmyride.com Dec 25, 2003 #8 Dec 25, 2003 #8 AFM B-451 !! 576/576 lift...hi rev camshaft..
mustanghrspower Founding Member Feb 27, 2001 554 0 0 46 Las Vegas, NV stangnet.cardomain.com Dec 25, 2003 #9 Dec 25, 2003 #9 Would the TFS Stage 2 cam have enough piston to valve clearance with stock 87-up pistons and TFS Twisted Wedge or Track Heat heads?
matty50racer Founding Member Nov 8, 2002 242 0 16 39 Pennsylvania Dec 25, 2003 #10 Dec 25, 2003 #10 mustanghrspower said: Would the TFS Stage 2 cam have enough piston to valve clearance with stock 87-up pistons and TFS Twisted Wedge or Track Heat heads? Click to expand... There is only one way to know, CHECK IT!!! it's not worth the risk of grenading a complete motor the first time the valves float a little bit.
