Hood shake problem build dates
Discussion in '2005 - 2009 Specific Tech' started by Florida Bob, May 17, 2005.
  1. Florida Bob New Member
    Nov 11, 2004
    Message Count:
    377
    My GT was built in December and I have the famous hood shaking problem starting at about 70 MPH or in strong winds. Anyone with a later build date NOT experiencing the same problem?
  2. Over's GT New Member
    Apr 1, 2005
    Message Count:
    72
  3. Florida Bob New Member
    Nov 11, 2004
    Message Count:
    377
    Thanks for the link. What I'm really trying to find out is if Ford has fixed the problem on later build dates.
  4. Owner1 New Member
    Apr 1, 2005
    Message Count:
    32
    My car was built in Janurary, and I get no hood shake regardless of speed. I've hit 120 maybe a dozen times, and I touch 100 most every day. Smooth as glass.
    Owner1
  5. bleedingvayneAD New Member
    Mar 31, 2005
    Message Count:
    340
    Ditto, even when I reached 145 there was no hood shaking at all.
  6. vacooley New Member
    Apr 11, 2005
    Message Count:
    35
    Jan build and no shake up to about 115. It does wobble a bit when passing a semi.
  7. Militarymustang New Member
    Mar 31, 2005
    Message Count:
    26
    Built week of Dec 13 and no shake up to 130
  8. Florida Bob New Member
    Nov 11, 2004
    Message Count:
    377
    Its interesting that so many people are not experiencing the hood shaking problem. It seems more and more likely that the hoods that do shake were mis-adjusted at the factory. My dealer can't seem to fix it though.
  9. Over's GT New Member
    Apr 1, 2005
    Message Count:
    72
    I know that dam thread is looooong, but if you read through it you can figure out that the early ones have the most shake and the later build dates have less and there hoods are a beach to close without slamming.
    I think this issue is still playing out so keep an eye out for a TSB
    I for one had mine up to about 125 and hood is solid, but I do have to slam it to close/latch completly. built mid /late March '05
    those out there posting your hood status, start informing if you have to slam to close
  10. Owner1 New Member
    Apr 1, 2005
    Message Count:
    32
    I don't have to "slam" the hood, if that means applying pressure in addition to letting gravity do the work. However, I would say it closes hard, as it does take at least a two foot drop for it to latch. The first several times I closed it I never dropped it from high enough, as it took more force to latch than I'd anticipated. I just chalked it up to being a light, aluminum hood.
    Owner1
  11. Florida Bob New Member
    Nov 11, 2004
    Message Count:
    377
    Yep. A TSB would be a great start and would give the dealers some guidance about what to adjust and how much. My dealer is clueless.
  12. Over's GT New Member
    Apr 1, 2005
    Message Count:
    72
    145 mph and all was fine, hood was like it was welded to fenders
    about 75 miles west of Phoenix on I-10, from 85mph down shifted to 4th and floored it, got close to red line in forth then pulled well into fifth, at aprox. 4500 rpm in 5th and 145-147 mph bounced the rev/speed limiter
    temps were in the 90's and no wind, no traffic, the car was very stable upto and for the 3 seconds at it limit, fun but very scary for my licence!
    I think this proves that ford can do it right up to it designed limits, if you have hood shake it CAN be fixed (just how and when is the debate)
    car was built in late May and hood has to be slammed or have pressure on front edge to close
  13. Florida Bob New Member
    Nov 11, 2004
    Message Count:
    377
    Agreed. Its the how and when that bothers me. Maybe an adjustment to the hood latching mechanism is the answer.
  14. nik73 New Member
    Nov 21, 2004
    Message Count:
    mine has had no hood shake up to 130 and was built 2/05 it also has to be dropped from at least 1.5 feet to close securely.
  15. 05Stangster New Member
    Mar 31, 2005
    Message Count:
    113
    I have the hood shaker problem at over 80 mph. Interesting about techniques for closing the hoods, though. Mine was built January 11 and is too easy to close. Gravity works fine with only about 6 inches.
  16. bigaloz New Member
    Nov 11, 2004
    Message Count:
    50
    no hood shake to report here, and I got my car last October
  17. CaptainSaveAHoe New Member
    May 24, 2005
    Message Count:
    26
    Car built in Late Dec and the hood shake scares the hell out of me...starting around 80 like everyone else w/that problem, i've touched 120 and was terrified. I'm replacing it with the saleen hood (has the vents) hopefully it'll fair a little better at higher speeds...but until then, SOME dealer has to know a way to fix it b/c i need speeeeed...*sigh*
  18. GottaBeRed New Member
    Mar 31, 2005
    Message Count:
    27
    Build date in Mid-December 04, and shakes over 85 mph.
    I'm wondering if the Saleen or cowl vent style hoods are the best solution.
  19. SLOW 97 Founding Member
    May 10, 2002
    Message Count:
    667
    Try adjusting the stops for the hood. Mine on my '97 were not adjusted right and the hood would shake violently at highway speeds. Close the hood and lift up or wiggle the hood around and you might be able to find whats causing the problem. Don't bother with the dealership, you should be able to fix this yourself with minimal effort.
  20. Florida Bob New Member
    Nov 11, 2004
    Message Count:
    377
    I raised the stops already but that doesn't help. The shake continues even though there is absolutely no play after the hood is closed. The car goes into service tomorrow to have the strut bearings replaced and the body shop manager says he has an idea of how to fix the hood shaking problem once and for all. Maybe he's thinking of taking it off and leaving it off. That's one way to fix the d--- thing. :)
Share This Page
