95riosnake said:
I too was wondering about it, if that's what it is in the pic. I've never seen one of these before and was wanting to know more about it.
I picked it up off of ebay, from a company that no longer exists. The guy knew NOTHING about it, it was honestly the worst service I've ever gotten from anyone on there.
Anyway, it's SUPPOSED to act as a support between the B-pillars, it basically bolts into where the base of your seatbelts bolts into. Then, after connecting both sides, you grab the wrench, which is included, and turn a little knob in the middle, which, in turn, pushes it out as much as you can. I'm sure it could be welded in, but really, for what it's supposed to do, squeezing it against the B-pillars is all you need.
Personally, I haven't noticed anything improved from it, except for my confidence that it will save my frame from lateral twists. When I picked up my subframe connectors, they were without a cross brace, and so, seeing that this would be a possible substitute for it, picked it up.
Keep in mind, I NEVER beat the car around corners, and basically drive it like a grandma most of the time...so maybe you guys, if you're willing to test it to a more extreme extent, might see that it is an improvement in lateral stiffening.
Answer to the question....ebay. I got it from ebay. Dammit.
