Ok. I have my car back together with the following mods:
I tried the stock tune that I was running b4 and the cobra tune and it seems to make no difference..
Trick Flow TW heads, 24# FR injectors, pro-m 75mm maf calibrated for 24# injectors (spliced to the old maf connector very tightly until i can get soder), 155 fuel pump.
Timing at 10 degress, sp gap set to 52, distributer is in perfectly checkled and rechecked that and wires....
When starting initially, I heard a bang or metal sound but then cranked it and it cranks fine, no metal sounds but I have to really keep the pedal down to keep it running and it runs rough. Take the pedal off and it dies. I am going to check and see if a rocker arm came off or something. Drivers side looks fine so I will be checking passenger side next. It sounds healthy, just that it is either getting too much fuel or like it is not running on all cylinders.
