Is it possible???
Discussion in 'SN95 4.6 Talk' started by miller766, Feb 8, 2007.
  1. miller766 New Member
    Jun 10, 2006
    Message Count:
    33
    I have put lot's of money into my 98 GT. Still I wish I had gotten a 99-04 bodystyle instead. Well what I was wondering was couldn't I just take the body off a 99-04 mustang and put it right on my frame? Nothing really changed from the 98-99s did it? What all would I need? I figure I could find a cheap body shell somewhere and it would be cheaper than buying a whole new car. So can it be done with no issues?
  2. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,691
    48
    No, cant be done. Its a unibody setup, there is no "frame" to speak of. Its all 1 peice.
  3. miller766 New Member
    Jun 10, 2006
    Message Count:
    33
    so the body from a 99-04 is that much different in size that it won't fit/work on a 98 setup?
  4. streetstang03 unModerator
    Dec 27, 2003
    Message Count:
    2,485
    yes, you can reskin a 94-98 to be a 99-04, i've seen it done before. dont do it though....too much $ to put into your car. Just buy a 99-04 GT. It will have less miles and wear and tear on the motor, tranny, suspension, body, interior etc...than your 98. it wont be cheaper than buying a new car.
  5. miller766 New Member
    Jun 10, 2006
    Message Count:
    33
    What would cost so much? I mean I understand that it would be worth it to just buy a new car but the only part of my car that isn't "newer" is the body so why not just replace that? I'm still a little confused about it though. So the body doesn't just lift up as one piece and slide onto mine?
  6. streetstang03 unModerator
    Dec 27, 2003
    Message Count:
    2,485
    no, not at all :rlaugh:
  7. AmBo Active Member
    Feb 3, 2004
    Message Count:
    1,048
    36
    You've been watching too much SPEED tv ;)
  8. urban96 bubb rubb says:"woo woooooo"
    Sep 25, 2002
    Message Count:
    4,233
    66
    it can be done, but it would be much cheaper/easier if you bought a 99-04 v6 donor and swapped over all your engine/trans/suspension/electrical stuff
  9. RoadconeTuning New Member
    Apr 4, 2006
    Message Count:
    461
    the SN95's dont have a frame on body.... its all one piece....
    unibody construction....
  10. 215what New Member
    Apr 14, 2005
    Message Count:
    167
    What's wrong with you? The 94-98 look bad ass when they have a nice set of rims and lowered. Is yours all 4x4 out?
  11. DCjuggalo New Member
    May 19, 2003
    Message Count:
    280
    dont do it man your lookin at a big head ache
  12. thomas91169 I'd donkey punch my sister.
    Aug 19, 2005
    Message Count:
    493
    it would not be a conversion for the faint hearted. its going to require ALOT of bodywork, as most of the skins will need to be welded on and adjusted. the front is relatively easy, you just need to get a 99-04 headlight header panel, front bumper, fenders and hood. you can find 99-04 doors so that is not a problem. the biggest headache will be the rear quarter panels.
    it would prolly be easier and more cost-effective to buy a 99-04, transfer everything you have on the current GT over, and sell the old GT and put all that into the new GT.
  13. 007 Founding Member
    Jan 29, 2002
    Message Count:
    3,109
    56
    Not a good idea IMO. Just by a newer car.
  14. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,550
    78
    You don't have a frame. The entire car is one peice.
  15. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,550
    78
    No. Cars haven't done that since the 70's.
    Cars are built as one peice these days.
    Besides, there is alot more that is different than just the outside. The suspension is slightly different, the brakes, the rear end is wider, the interior is different, stereo is different, defrost, fogs and other accessories are wired differently, different trans etc.
    What exactly to you like better about the 99+? You can always do a PI swap and have a 260HP 4.6L just like the 99+ Mustangs.
    If you want just the sheet metal, it's cheaper to sell your car and buy one
  16. RedGTvert Founding Member
    Nov 21, 1999
    Message Count:
    3,204
    No mustang has ever had a frame. They have been unibody since the first one rolled off the assembly line in 1964.
Share This Page
