If your idle didnt degrade when the EGR was open, your EGR wasnt working properly. There's no way an open EGR at idle would be near smooth enough to pass an inspection. Anyone wanna test this: With the car idling, apply 6" or so of vac to the EGR (you can connect a rubber hose and suck on it even). The car's idle will go right down the crapper. For Mr Duncan, if you notice your idle go to crap when you suck on the EGR nipple then we'd want to check your vac line, EVR and position sensor. The Valve (a slave) might be fine but it's not getting the correct input.
Never thought nipple sucking could be so boring. FWIW - I removed my EGR for the exact reason the car wouldn't idle when it stuck open.
If you read my message you would see where I stated that there was a blockoff plate between the EGR and the upper... So the Computer thought it was wide open when it was really doing nothing.
So I have three options. #1. I already paid Midas $189.xx for the e-test + diagnostic. If I pay them another $260.xx I can get new O2 sensors, PCV valve, Oil change, Timing check, and decarbonization and a conditional pass which is good for two years. #2 I can go to a local shop (what I should have done in the first place), pay them $180.xx and get a conditional pass for two years. #3 Take the car off the road, source an H pipe, change the 02 sensors, PCV, oil myself. Take out spout, run some GTP and then pray it will pass the test. This will probably end up costing more than the other two options, and I won't have the car on the road for at least two weeks. What would you do, if you were me?
#1 $100 and a cookie. #2 ... same exact looking car dettachable vin (no I would never do anything il-legal!!!) #3 .....move to a state with no emissions.
Duncan, If number 1 gives you parts you need for your money (vs #2. The O2s alone cover the extra cost), I'd do that. Then over the next two years, find a nice clean H-pipe for the next time around. Chris, if you knew you had a block-off plate, why did you disagree with my [correct on cars as they come from the factory] statement? I guess you were suggesting that Duncan puts a block off plate on his EGR and then apply manifold vac to the valve (to mimic what you had)? I guess I don't understand the point of your post.
Yeah. I think I will be going with #2. Despite the fact that I don't want to hand them the cash (I'm not totally satisfied with their quality). Regardless though, it seems to make the most sense to at least get some new O2s out of it. I'll let you know how it goes tomorrow
So they want $140 each for the 02s. I'm back to square one now. They said I could buy them on my own, bring them to them, and then they could put other work towards the $260 I'll have to pay to get a conditional...but then I'm out whatever it costs me to source the 02s on my own + $260. Option #1 is looking a lot better now. I'm also considering option #4, sell the car, and build my Audi.
How much are the o@s if you bought new ones? That is the real cost delta you need to look at? How much is the re-test if you just run G2P and pull some timing? I would try this first as it is failry cheap to do...
I'm so ****ing pissed right now. Went out, bought an $80 O2 sensor, went to pay them their money, and they wanted $450 + TAXES AND RETEST. So basically $520 + for new O2 sensors and two failing e-tests. I told them to go **** themselves hard. So now I'm not sure what I'm going to do. I don't even want to drive the car anymore.
WTF??? Whatever happened to option #2? Pay for the conditional pass? Changing both O2's takes no more than 15 minutes under the car. Thats crazy
Midas is awful. Never let them touch your car. I couldn't believe the price they were asking for stuff. $100 to install both O2 sensors?? What hourly rate does that work out to? wow. I'm going with option #2 next Monday.
Oh, and do you think I should bite the bullet and buy another O2 sensor and install it and the one I bought today? Would this fix my rich condition? If it won't, I'll probably just take back the one I bought today.
