- Dec 13, 2004
- 11
- 0
- 0
First time I went to the track it wasn't that busy so I got to run about eight times and finally squeaked out a 13.8 that night in stock form. Last night I only got three runs and not once did I have a decent launch. Now I have a JLT II intake and should be running better than 13.8 but never saw under 14.1. Seems like if I launch around 1k I bog and if I creep to around 2k when going full throttle I will spin all the way through 1st. Once it breaks traction I guess there isn't anything you can do.
It doesn't help that the track I am at sprays that damn water down every damn time a car pulls up even on street night. You can drive around the water trap but you are still getting runnoff water on your tires. With the traction issues I am getting 2.5 60' times. On the run I got 13.8 my 60' was 2.2. I still managed to trap 103.5 at 14.1.
It is pretty embarassing to run a 14.1-14.3 in a car that should be doing a 13.5 easy. I also find it hard to practice when it is so damn busy. Seems like the second you get the car lined up the lights are coming down. Any advice would be appreciated.
