Whenever I push the button in the glovebox nothing happens. I'm guessing that there is an electric motor bad, but how hard is it to fix, is it expensive, and am I totally wrong. I'm tired of pulling the cord in my hatch every time I get gas.
not a motor. It's just a solenoid. I've never replaced one though, just remoed it. I don't imagine it would be too expensive but I'd check power to the one that's in there before I went about changing it.
right on Daggar. it is very possible that the button in the glove box went south. put a test light on the connector and see if you have 12 volts coming out of the button when it is pressed. you can also check the continuity of the switch too.
If your power mirrors don't work either then check out fuse #8. Aside from that definately check the switch and wiring before you replace the solenoid.
I removed the little bracket on the door that locks it so I don't have to bother with it anymore, anyone could break the lock just by pulling, and it's more of an inconveniance to me than anything
You should be hooking up some Naws or something, not fooling with that thing. Just take the latch off and throw it away as was stated above. Get a locking gas cap if you are worried about tampering or someone stealing your fuel.
