I did the searches to fix my hanging idle, and determined that the only thing left to try was this IAC restrictor plate. I made one and installed it yesterday, and now NO MORE HANGING IDLE! Yay! Well, the only problem was that I wasn't sure the best way to adjust my idle after I installed the plate, so I left the IAC screw out all the way and adjusted my idle using the throttle plate screw. The hole I drilled in the IAC plate was the smallest recommended (5/32") so I figured I would not want to restrict it any more by using the IAC adjustment screw.
Well, now my problem is that the car is VERY hard to start when warm and surges like crazy when I do finally get it started and continues for about 30-60 seconds and then it runs just fine. At cold start it runs better than ever and no hanging or surging. I checked the codes (even though I am not getting a CEL) and I pulled a 121-"TPS out of range", 334-"EVP sensor is/was high", and 565-"Canister Purge 1 solenoid/circuit failure - Solenoids"
I'm not concered with the EVP sensor since I am not using an EGR valve, but the Canister Purge 1 gives me a little concern as does the TPS sensor code. BTW, I have replaced my TPS with a new OEM Ford one recently and I have also tried using other IACs (not new, though).
