Need help choosing amp!
Discussion in 'Mustang Sound & Shine All' started by Dtowncats, Sep 20, 2004.
  1. Dtowncats New Member
    Jun 3, 2003
    Message Count:
    352
    York, PA
    Well I have most of my system pieced together. I have the Alpine head unit, Infinty speakers all around, and the Infinity Kappa Perfect subwoofer. The subwoofer is a 10" and rated at 350 watts RMS and 1400 watts peak. I am stuck on which amp to get so if anyone has any input or opinions that would be a ton of help. Thanks!
  2. MyEarsHurt New Member
    May 21, 2004
    Message Count:
    926
    Well I would say go with a rockford or audiobahn, those are my favs. Really, anything you buy that is at least $1.00 per watt rms in 4 ohm will be good. So if you need some that puts out 350 rms in 4 ohm then you will expect to pay $350 or more for a solid amp that will sound good. HOWEVER, if you need 350 wrms in 2 ohm, then you can probably get away with spending closer to $200 bucks for the amp.
    This is nice, so I hear... http://www.cardomain.com/item/ROCP3001 Rockford underrates all of their products. For example, I bought a 350 watt amp from them once, and it came with a "birth certificate" which stated it actually put out 391 when they tested it! So even though this amp is only rated at 300 wrms, it will put out more than that.
    Now that I think about it, audiobahn doesnt make many amps with that small of wattage. So maybe you shouldnt bother with them....Good luck... :nice:
  3. Dtowncats New Member
    Jun 3, 2003
    Message Count:
    352
    York, PA
    I found some of those RF amps on Ebay for right around 150 each. The peak power is 900 watts though. Would you recommend a capacitator?
  4. nocaratall New Member
    Feb 12, 2004
    Message Count:
    132
    check out www.sounddomain.com and search through the forums. alot of pros over there will be more than glad to help.
Share This Page
