need help removing the grill
Discussion in 'SN95 4.6 Talk' started by mustangkid05, Jul 9, 2006.
  1. mustangkid05 New Member
    Mar 10, 2006
    Message Count:
    217
    well i got the 5 screw out of the top of the grill, but i didn't know there was 5 at the bottom...is there an easier way to take the grill out thanks
    romaine
  2. SaleenGT2001 Active Member
    Jul 19, 2005
    Message Count:
    2,925
    46
    Four Oaks NC
    remove the front bumper cover. all that is holding it on is 2 13mm nuts on each corner under the headlights. you can access them thru the bottom of the bumper. it will be next to impossible to remove the grill with the bumper on.
  3. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,317
    76
    Fort Wayne, IN
    I took mine off without removing the bumper cover. It takes time but it can be done.
    A ratcheting box end would be helpful.
  4. FivePointStang Founding Member
    May 22, 2001
    Message Count:
    290
    Springfield, OH
    Removing the bumper seems a bit excessive. Once you have the two screws off from the top, remove the headlights (this allows you to have more room for your hands). After that pull the grill forward, you will be suprised how far it can come forward. I was afraid of breaking it the whole time, but I read a post on here saying to pull away, so I did. Now you should be able to get the remaining bolts...
  5. AmBo Active Member
    Feb 3, 2004
    Message Count:
    1,052
    36
    New Jersey
    Patience my friend is key to all mods. :) You'll get em off, but you don't have to remove the front bumper by any means! It was my first mod and I figured it out. Keep at it!
  6. MarcoCapone Member
    Aug 6, 2003
    Message Count:
    43
    I just did mine last month.... You doesn't have to remove the bumper,you just have to pull the grill a little bit, just enough so you can touch the bolt underneath it, and unscrew them by hand (I didn't even needed to use a ratchet just the box and a good pair of glove to have a good grip...)!!! Anyways its suprising how you can pull on the grill without any damage to the bumper!!!
  7. Mustang225 Founding Member
    Jul 23, 2000
    Message Count:
    401
    If I recall I used a 7mm wrench to get the screws off. Just needed to pull it up and closer to you.
  8. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,738
    48
    I did mine today, and it sure was a **** getting those bottom bolts off. I also just pulled/bent the cover up.
Share This Page
