I have searched the frorum and found other members having problems close to what mine is, but no exact matches.
I just bought a 1990 Gt off of Craigslist, the guy said it ran find, but needed a new battery. When I went to look at the car he had a new battery in it and said that he thought the fuel pump must have quit working now. I made him an offer and bought the car not running. Once I got it home, I found out he had hooked up the battery wrong, after correctly hooking up the battery the car will crank and then dies after 1-3 seconds. I replaced the ignition module (under the dash) and the module on the distributor. I checked the roll over switch near the left tail light (under plastic). Fuel will come out of the schrader valve when pressed, I have not checked the fuel pressure yet. Do you guys think the computer is shot from the battery being hooked up wrong? What should I try next, should it have an OBD code ( check engine light is not on)? Thanks for any help!
