NO BELT TENSIONER??
Discussion in 'Fox 5.0 Mustang Tech' started by Georgie, Apr 7, 2006.
  1. nidyanazo Banned
    Mar 31, 2005
    Message Count:
    186
    805 dawg
    Reverse rot. water pump, and you will need a longer belt.
  2. Georgie New Member
    Jul 13, 2005
    Message Count:
    458
    Montreal, Canada
    ok man thanx alot... u welded the seem on ur floor pan??? i was thinking of doing this be4 i finish putting on the new carpet and 6t point....
    gimme some info on that dude....
    Sponsored Ad
  3. smokin91' New Member
    Feb 20, 2006
    Message Count:
    207
    Look at the part i have circled, the lower allternato bolt. Looks like whoever did that broke that braket and homejobbed some sleeve and stuck it in there. Anyone else see what Im seeing?
    [IMG]
  4. Georgie New Member
    Jul 13, 2005
    Message Count:
    458
    Montreal, Canada
    YES IVE NOITCED HIS..WHAT SHOULD I DO...I HAVE ACCES TO A BASIC MACHINE SHOP AND TIG WELDER
  5. smokin91' New Member
    Feb 20, 2006
    Message Count:
    207
    I dont know if that bracket can be welded, and even if it could, you would be better off just getting a new bracket WITH a belt tensioner off of a junk car. If you weld and fix it you still have the problem of having no belt tensioner.
    This way you can fix 2 problems at the same time, and it will be cheaper then having that welded.
  6. Maryland Stang Active Member
    Aug 21, 2002
    Message Count:
    1,534
    36
    Swift Creek, NC
    The bracket may be broken but the sleeve is the responsibility of Ford. It comes that way from the factory. My '92 has the exact same sleeve.
  7. smokin91' New Member
    Feb 20, 2006
    Message Count:
    207
    mine has a solid piece of metal that the bolt threads into. That sleeve on his car doesnt look right. the metal is broken at the edge
  8. Georgie New Member
    Jul 13, 2005
    Message Count:
    458
    Montreal, Canada
    OK MAN THANX A BUNCH
Share This Page
