well my 94gt will not turn over, I replaced the starter since it was making a tinging noise like the noid was bad, and also put my batt. on a charger and tested it and its ok. with a new starter and good batt. it will still not turn over. I also checked under the hood fuses as well as the fuse panel inside the car all was good. Here is the weird thing when I was looking and listening under the hood I noticed my N2o fuel line for my wet kit running off my schrader(sp?) valve was realy friggin hot, I mean hot enough to start melting a rubber fuel line hose I wraped it in to keep the line more lo key as well as protect any wires from the sharp braided line. I also get a puff of smoke from the E-brake handle that smells like electricle short, but I removed my console to look at the wires and they are ok, so I made it smoke and saw it was coming from under the car and inside through the cable gromet on the floor, Then I jacked the car up to see if any wires were bad and there is no wire anywhere near the that part of the car???? only what looks like a hard fuel line group that would not make a burning wire smell so WTF.
Help please fellow sn95'ers
Thanks Greg
Thanks Greg
