I put in my a-trim and took it for a test drive, I have a boost gauge with vacuum, and when I get on it, the vacuum goes up to 0 holds, then goes up to like 1-2psi around 4000-4200rpm.
I've got a power pipe, a 6" crank pulley, and a 3.12" blower pulley.
Shouldn't I be making boost much sooner? What could the problem be? I have the belt on not extremely tight, but it's on, I just pushed down on the pulley and tightened it up, I didn't use a wrench (should I have?) How tight is the belt supposed to be? Should it be really cranked on there? With virtually no play?
