Thanks all!
Here is the mod list as much as I can remember.
Engine:
Paxton Novi 2000 Supercharger
Reichard Racing Ultra Grip 15psi Pulley
Paxton Air-to-Air Charge Cooler
Custom Machined Steel Supercharger Idler Braket
Vortech Bypass Valve
C&L Plenum
BBK Throttle Body
Siemens 60lb. Injectors
SCT 2600 Big Air MAF
Snow Performance Stage 2 Boost Cooler (Meth Injection)
Moroso Oil Pan (7 qt.)
Coated Diamond Pistons 18cc dish
Manley H-Beam Rods
03 Cobra Crank
.20 overbore
ARP Main and Head Studs
High Performance Oil Pump with Billet Gears
New Chains and Guides
Crower Stage 2 Blower Cams
Heavy Duty Valve Springs
SCT Flip Chip
Tuned by Steeda.ca
Driveline:
Dynamic Racing Mighty Mite C4 Transmission
4.6 SFI C4 Bell Housing
Custom 46" Long 4" dia. Steel Driveshaft
Moser Engineering M9 Fabricated 9" Rear End
Moser Engineering 35 Spline Axles
Moser Engineering Full Spool
Moser Engineering 3.73 Gears
Driveshaft Loop
Suspension:
90/10 Lakewood Struts
UPR K-Member
Steeda Rear
Lower Control Arms
Steeda Double Adjsutable
Upper Control Arms
Airbag in Right Rear Spring
Custom 4pt. Rollbar
Custom Tubular Subframe Connectors
Fuel:
03 Cobra Tank/Pumps
External Filter
-8 Line to filer -6 Line to Rail
Kenne Bell Boost-a-Pump
Exhaust:
Custom exhaust w/
Borla Mufflers
Wheels:
TSW Bremma 20x10 rear, 18x8 front
Centerline Telstar 15" w/ 29"x10.5: Hoosier Quicktime Pro DOT drag slicks (Drag Rear)
Weld Prostar 15" skinnies (Drag front)
Other Mods:
Autometer Gauges (Oil Pressure, Boost, Tranny Oil Temp, Water Temp)
Transmission Brake Switch
B&M Shifter
Celica Seats
Steeda Cowl Hood
Batery Relocation Kit
