question about lower control arms
jhonda
125
Huntersville NC
I am looking to replace the rubber bushings in my rear lower control arms with some urathane(spelling) bushings because my stock ones are shot. Question is does anyone have a diagram for some reinforcement plates that I can weld on the bottom of them to box them in...I am a pretty good welder so that doesn't concern me. Reason I would like to do this is money, using stock suspension peices so I can say "stock suspension" when someone asks me at the track, and to be differant.
Thanks
Jason
Its fairly easy to just get some 1/8 steel, make a couple of cardboard templates and cut out the reinforcing plates.
Thats how I did it, then just weld them in. The arms are galvanized, so you have to grind off the galv where you want to weld.
You could recess the plates in the arms or make them fit on the bottom, either works, and they don't have to be precise to have contact to weld.
I even welded some brackets for the rear sway bar so I could put it back on.
