I have an FRPP 2 row I got from LRS. It is a bit pricey at $240 but not as bad as those rads with the polished aluminum end tanks at $380. The FRPP rad is aluminum with HD plastic end tanks. I can tell a big difference in the quality of plastic material vs the cheap Cardone/Ready Rad I have in my V6. It's plastic, but it's a LOT thicker. The core is all aluminum with HD fins, not the type that crush just by brushing against them. And FYI, aluuminum is the best when it comes to heat dissipation. Why do you think that heat sinks for amps are made of aluminum? That autozone 3 core is made by Rready Rad, it's heavy ( 3 times the weight of the FRPP) and it has cheap steel frame and tanks that start rusting too easily. Only reason I have a RR rad in my V6 is because I didn't have much of a choice, and needed a new one because my stock rad split from too much pressure. Yeah, I know what you're thinking, the FRPP is plastic and that means it'll split also..... NOT so. First, the factory rad was cheap as is the replacement. Second, whatever was causing the pressure problems stopped once I stopped using thermostats. The HC is probably clogged. And 3rd, the FRPP rad is made a lot better than that RR junk. It's made for higher HP applications so the material is a lot thicker. When it comes to the cooling system, I wont muck around with cheap components. I plan to change out the RR in my V6 for something a little better.
