i'm making my own battery relocation kit. basically a taylor copy cat kit but the box will be designed to fit my battery so it takes up less room and wont be as big.
my plan is to put it in the trunk in the passenger corner behind the tail lights area. i'm gonna run the cutoff switch behind the plate so its hidden. i'm gonna go to a wrecker and find an old trans am or similar car that has the licesnce plate frame with a spring loaded hinge on it so i get easy access to it.
my question is how did you guys wire up your battery?
i remember seeing an old post but i cant find it.
i'm going to be using welding cable because its a better conductor and easier to route.
i still run quad shocks. should i still use it as a good ground?
what have you guys had sucess with?
thanks
thanks
