Removing rear seat backs
94DreamGT
593
Indiana
Stupid question, but my Haynes manual doesn't show crap and a search didn't provide any good info.
I got the bottom cushion out by pushing back on the two tabs.
Now for the seat backs...I took out the two 10mm bolts on either side of the bottom, but then I was told to just lift up and out??? The whole thing is still attached to the frame of the back. Do I have to take more bolts out?
Thanks
I'm not sure if it is different between coupes and convertibles, but in my car, once you take out the lower part, you take out the two bolts on each side and pull/push straight up. If you look behind the back seat, you should see two tabs that hook the seat in place. Removing the back part of the seat is the same type of process that taking off the door panel is.
Joe
