Removing side scoop from quarter panel??
Discussion in '2005 - 2009 Specific Tech' started by 1965coupe, Oct 17, 2007.
  1. 1965coupe Member
    Jan 2, 2004
    Message Count:
    213
    My passenger side scoop has never been completely attached to the car.. The double-sided tape did not stick very well from the factory... (from Ford, not Shelby.. so no Shelby GT bashing :nonono: )..
    Rather than go the dealership route (they CANNOT "re-tape" the scoop, they have to order another, and paint it, which means leaving the car there overnight :notnice: ), I bought some 3M tape (at an auto paint store) and some wax/grease remover spray...
    So, since the scoop is already hanging off about halfway, can I just finish pulling it off? I know there are two plastic "pins" that are still holding it on..
    Do I need to go in from the other side??
    Any other advice??
    Thanks. :nice:
  2. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    i assume the plastic retaining clips are similar to the ones used on the truck wheel flares. you would be best off to go from the inside. remove the 1/4 trim panel, and you should be able to see them, and how they come off.
    for the cleaning and retape, use the wax/grease remove and soak the tape. use a razor blade perpendicular to the part and scrpae it off. this prevents you frim cutting into the scoop accidentally. once its all cleaned up, use some 3M adhesion promoter. it comes in a small package and its a wipe. wipe it on where you are gonna put the tape. let it dry, and then apply the tape. this will help make sure that the tape sticks to the part REALLY GOOD. i have cleaned and retaped hundreds of mouldings, and have never had a comeback. this procedure will work.
  3. 1965coupe Member
    Jan 2, 2004
    Message Count:
    213
    You wouldn't happen to know how to pull off the interior panels, would you? :D
  4. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    its been a long time since i have pulled them, so im not 100%. i think jenn has a link for them though. pull the rear seat bottom out. there are 2 plastic clips that hold it in, just push them in, and pull up. i believe they are 8-12" in from the edges of the seat. there should be a plastic christmas tree style clip on the front edge of the seat riser where it drops down into the footwell. i think you also need to pull up the door sill plate. that should just pop up with a little effort. once these are out of the way, i think the rest is self explanatory, but like i said, its been a while. jenn will be away for a few more days, so she may not reply right away to this thread if she has a link to the PDF.
  5. 1965coupe Member
    Jan 2, 2004
    Message Count:
    213
    Thanks bigcat! :nice:
  6. Jenns01TA Active Member
    Mar 31, 2005
    Message Count:
    1,112
    36
    Hey Guys,
    I'm back from another 2,500 mile trek across the US. :) Almost 10,000 miles in less than a month. CRAZY!
    1965Coupe - Email me from outside the Stangnet server @ Jenns05Stang@sbcglobal.net and I'll send you the PDF if you have not figured it out already.
    ~J~
    Jenn
  7. Jenns01TA Active Member
    Mar 31, 2005
    Message Count:
    1,112
    36
    Email sent. Let me know if you need something else.
    ~J~
  8. JLTucker New Member
    May 26, 2004
    Message Count:
    117
    They are push style clips, just pull it off the rest of the way. The clips may break, but that's normal.
  9. 1965coupe Member
    Jan 2, 2004
    Message Count:
    213
    Are the clips pretty standard as far as Ford hardware?
    I don't know if I can pick them up in town, or if they need to be ordered...
  10. anthony05gt New Member
    Mar 19, 2006
    Message Count:
    1,268
    Another thing I've found that works is once the scoop is ready to go back on the car, put it in front of a heat source and get it warm and put a hair dryer to the car to heat up the paint surface. After it's stuck on continue to apply pressure around the taped perimeter until it cools down.
Share This Page
