Posted up a couple of days ago and got no responses. Hoping to get a couple this time.... Problem is that the stang won't idle right. In park and neutral it's fine, but in reverse or drive it won't stay still, just goes up and down and sometimes dies. I took off the battery for about a half hour with the door open to see if the computer just needed to be reset cause I just put a 65mm TB on, and that took care of the check engine light that had been coming on I think, but I've only driven it one time so... Anyway, tried to adjust the idle...turned it up too much and the car kinda surged a little while I was driving so I turned it back down. I read around a little bit and think it might be the IAC, cause that controls the idle when the car is just sitting, but that's my best guess. The only thing is that wouldn't the idle be bad in park and neutral too?...and if that's bad, why was it running fine before the swap? Really could use some help cause this is getting a little frustrating. Thanks.
