S197 vs previous years
Discussion in '2005 - 2012 (S-197) Mustang' started by Dreadnaught, Sep 7, 2007.
  1. tomustang Psychotic Member
    Jun 8, 2000
    Message Count:
    5,018
    76
    McLean Hospital
    Seems like you are flawed too, I've seen DR's wipe off .5 on the strip, you on the other hand lost .06 :scratch:
    Plenum = 2~hp
    UD's = 5~hp
    X-pipe = 6-7~hp
    Flows = 0hp
    You have a tune w/ higher octane, higher gear, your stall makes up for the auto to manual difference..
    Ok he spanked you on trap speed, which means he's faster, he is putting down less power and is faster than you
    99-04 are close to 3400lbs
    05+ are closer to 3550lbs
  2. shadowland2000 New Member
    Mar 28, 2003
    Message Count:
    97
    Well the V6 is only .6L smaller in displacement than the V8, and that's with 2 less cylinders. It's a big V6. However, it's actually a fairly primitive V6 compared to most sport cars these days. The 350Z engine gets about the same milage with another 100 horses.
  3. 313Speed New Member
    Sep 12, 2004
    Message Count:
    Actually, that was with the original 5.0, 160k on the odo... headers and a CAI were the only mods, though it was converted to a two seater, so there was a weight advantage.
  4. Mr_K_Code65 New Member
    Sep 19, 2004
    Message Count:
    12
    So I read this post and had to go back and remind myself of how fast my '85 stock GT felt. Car and Driver January 1985 road test of the GT (title "time to catch the 302 and we're not talking Amtrak.") lists 0-60 at 6.4 secs and 1/4 mile 14.9/91 mph. Damn it was $11,391 brand new.
  5. shooterm1 New Member
    Jul 19, 2005
    Message Count:
    546
    Milford, Pennsylvania USA
    Numbers that are comparable to the current V6.
    but I digress......
  6. 93GrunT Founding Member
    Dec 17, 2000
    Message Count:
    531
    NC
    I have been away from the 5.0 tech forums for about 3 years, but from the few years I did spend there I am certain that 87 through 92 5 liters were rated at 225 hp and 300 ft/lbs of torque from the factory. It just sounded like the other guy was talking from first hand experience on a dyno with fox bodies in his first post so I wasn't going to argue about it. However it really sounded like some kind of distorted interpretation of what I have read and poopdawg later cleared up.
  7. Five Oh Brian New Member
    Jun 14, 2007
    Message Count:
    564
    Pacific Northwest
    I melted my factory tires to get it to launch hard enough to run 13.32. My average runs on the factory tires were inconsistent with some in the 13.3's, but many in the 13.4's and 13.5's. With drag radials, traction a non-issue, and I consistently run 13.30's all day now. So, I'd say that on average, the drag radials helped immensely. My prior Mustang (03 Mach 1) was a stick shift car with 4.30's, and drag radials were a must on that car. Best ET with factory tires was 13.36, while with D/R's it was 13.01.
    I pride myself on making the most of a factory tire, so I don't believe my racing skills are flawed at all. That 13.32 run in my 07 GT on factory tires was with a 1.86 60' time. With drag radials, I'm pulling 60' times in the 1.8's all day long, while most people can't seem to pull under 2.0's and many are in the 2.2's and higher. I'd boast that I can launch a drag car much better than the average guy.
  8. Five Oh Brian New Member
    Jun 14, 2007
    Message Count:
    564
    Pacific Northwest
    We have DOT truck scales on I-5 near my home, so I've weighed all of my cars there over the years. They claim to be accurate to within +/- 20 lbs. I always weigh them with a 1/4 tank of fuel, and I leave everything in the car as Ford delivered it for consistency sake. Here's what my last three Mustangs weighed....
    3,180 lbs = 2000 Mustang GT 5-speed coupe.
    3,380 lbs = 2003 Mach 1 5-speed coupe (heavier 32 valve motor).
    3,490 lbs = 2007 Mustang GT automatic coupe (auto weighs 180 lbs more than manual according to Ford, FYI, so a manual GT coupe should weigh about 3,300 lbs roughly).
    The only 99-04's that were 3400 lbs were the 32 valve cars (Cobras and Mach 1's) or convertibles. GT coupes were a couple hundred less, with the manual GT coupes being the lightest of the bunch, of course.
  9. Five Oh Brian New Member
    Jun 14, 2007
    Message Count:
    564
    Pacific Northwest
    My 07 GT has run 103 mph in the 1/4 mile earlier in the season when the temps were cooler (and that was before adding the stall converter and drag radials). My best ET of 13.28 just happened to be on a hot and muggy day so my trap speeds were lower. I posted uncorrected #'s right off the timeslip even though the DA was sky high that day.
    If you'd like to accurately compare the two cars' timeslips, either line 'em up on the same track on the same day, or we could use DA corrections to level the playing field. For example, the correction for my car's best ET puts my car in the 13.05 range at about 103.5 mph. And I still haven't programmed my stall converter to lock up earlier in 4th gear, so it's slipping a lot at the end of the 1/4 mile (likely costing me 1-2 mph). Gotta have a custom tune written to lock up the converter (unless someone knows how I can do it myself with my Predator tuner?).
    Also, keep in mind that Modular2v's car is a heavy breather with good airflow mods (great for a top-end charge to the finish line), while my car is sucking through a straw (factory airbox, factory exhaust, etc.). I didn't mod my car for high speed via airflow mods as I rarely need to pull hard at 100 mph (except at the drags 5 or 6 times a year). I modded my 07 GT with launching hard in mind, which I can use everyday on the street, and also benefit from at the track. Someday I will do airflow mods when the car would benefit from them (i.e. bigger cams and/or supercharger), but the 3V motor breathes fairly well when stock or lightly modded.
    It would be interesting to compare short times for the two cars. My car's uncorrected true and correct numbers for the early part of the 1/4 mile are in the 1.80's for the 60', 5.40's for the 330', and 8.40's for the 1/8 mile (at roughly 82 mph). I'm curious how Modular2V's 2003 GT compares with these numbers.
  10. kooldawg6 mine works really well and can take a fair amount
    Aug 31, 2006
    Message Count:
    1,718
    Central VA
    Here is a timeslip from my '00 5 spd GT. All I had done were Flowmaster mufflers and Eibach lowering springs. This was the first and only time I raced it(ran it maybe 6 times that night-this was the best run), so it might not be stellar, but it should be a decent reference.
    [IMG]
  11. jlisle01 New Member
    Dec 29, 2004
    Message Count:
    250
    McAlester,OK
    Now, now, people. I think the question is; "should he keep the six stock and wait for something better or mod the 6 up". I'd keep her stock and wait for a special edition. I've heard about a possible Bullit with a 302? Sounds good to me. And if the body changes in '09 make you want to puke there will always be some used GT's to pick from. I'm not nockin' the six, it's just that if you're asking, I'm thinking that down the road you'd be playing the "now, if I'd started with a V8" game. Double the salary? Get what you really want - you earned it.
  12. tank_567 Member
    Mar 20, 2007
    Message Count:
    571
    18
    Raleigh, Nc
    I have a 98 gt vert my very first time down the track i ran a 15.1@89 stock. Next Time I ran down the track I ran a 14.7@91 stock. I've also seen many 05 v6 run mid 15s and I've seen a 06 vert v6 with cold air, pulley and a tune run a 15.2@91.
Share This Page
