Slp longtubes
Discussion in 'SN95 4.6 Talk' started by 2002tbstang, Oct 31, 2007.
  1. 2002tbstang New Member
    Jan 8, 2007
    Message Count:
    26
    I was just wondering who here has SlP longtubes and would like to know what you guys think about them. I have the slp X pipe already and was also wondering if they need to be taken off to reach other things or for any repairs
  2. ADRENLN Active Member
    Apr 16, 2003
    Message Count:
    2,376
    46
    i have them and like them a lot. there was a good power and torque gain. however, i believe that they d ohave to be removed for other type of repairs. has me second guessing them. down the line they might cost me some serious cash.
    otherwise i love them.
  3. 2002tbstang New Member
    Jan 8, 2007
    Message Count:
    26
    Thats what I am worried about, I dont want to find out down the road that some repairs would have to be hundreds of dollars more because of the headers and labor is expensive over here
  4. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,458
    10
    78
    Im unsure as to exactly what your asking. Do you already have slp longtube headers? From the sound of your first post, it sounds like you just have the x pipe, with stock exhuast manifolds. If that is the case, you will have to either have an exhuast shop chop your x pipe and custom fit it, or have a new one ordered if you add LT headers. The "stock size" midpipe, even if changed to an aftermarket one, will not fit with LT headers.
    If I misinterpreted your original post, sorry..
    Years back, when LT headers were being produced, a couple of the guys around back then did a lot of test with LT headers. The best performing LT header back then was always Mac. The fit on them was marginal, or worse than.... However, they always outperformed BBK, and the small amount of others. With them, we also took a tranny out of a 5 speed with them bolted up if I can remember right.
    Later on, I was one of the first cars to run reground after market cams with a 2v. We bolted up a set of kooks and the fit and finish was awesome. It looked like there was plenty of room to remove the tranny for work.
  5. superstang01 Member
    Oct 11, 2006
    Message Count:
    286
    negative. SLP's catted X can be used with shorties and longtubes....it comes apart after the cats for use with longtubes
  6. 2002tbstang New Member
    Jan 8, 2007
    Message Count:
    26
    Well Thanks, thats good to hear because that was my only concern about the longtubes. Its time to start saving again :D. Now I just need to find a shop that will put them in.
  7. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,458
    10
    78
    thanks, much to learn after being away for 6 years!
  8. superstang01 Member
    Oct 11, 2006
    Message Count:
    286
    all good man, i only no because i am looking at ordering one for that very reason lol
  9. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,642
    36
    i got it, wont get to use that benifit tho due to damn Cali rules. But the bad side for it to work w/ LT's is that it hangs really low.
  10. ADRENLN Active Member
    Apr 16, 2003
    Message Count:
    2,376
    46
    yea it does hang real low, i cant even drop my car as much as i want to because of them. but it was looks or power at the time and i chose power.
    now that i have then i think im only gonna drop it 1 1/2 in. but even that will only give me like 3 in. of clearance.
  11. 2002tbstang New Member
    Jan 8, 2007
    Message Count:
    26
    My cats on the X-pipe are very low but the headers wouldnt be lower than the cats would they?
  12. ADRENLN Active Member
    Apr 16, 2003
    Message Count:
    2,376
    46
    no the headers wonr be lower then the cats but i think the addition of the headers lowerc the placement of the cats.
  13. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,458
    10
    78
    proboly so, but you can have an exhuast shop with a lift tighten up your whole system and raise it an inch or two
    I had to do it with my custom side pipes on my old car, but just make sure the cat backs dont rub on the axle, brake lines, or anything else.
  14. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,642
    36
    custom side pipes crew:nice: Yeah watch out for driveshaft vs. exhaust clearence for sucking it up closer to the body
  15. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,458
    10
    78
    nice! my old setup was ghetto:rlaugh: I had two chamber flows that hung so low to the ground, and we welded them close to the frame. It looked fine, the car was dropped and you couldnt see it, we used crome dual 2 1/2 inch tips with a y pipe splitting them on each side! Im trying to dig up some old pics!! I nearly tore them off on every speed bump, didnt go with the svo kit, too pricey, and i figured the mufflers with the inlet/outlet on the same side lost flow velocity due to the 180 bend the exhuast through the muffler, but proboly not much in retrospect on my head/cam car. Eitherway, it was fun! But it wasnt as clean looking as your setup!:flag:
    ok, no more hijacking:)
Share This Page
