89MustangGX said:
I don't see how having some solids and some poly would be good -- the way I think about it, you would want either all solids or all flexing. With the engine and tranny directly connected together, I don't want part of it flexing and part of it solid.
As for the ASP's -- I don't see a point to a solid mount that allows some flex???
I have the Maximum Motorsports to install (engine and tranny) and they are very nice looking -- also inexpensive compared to others.
The chassis flexes.
The motor and tranny are linked solidly.
If the tranny is mounted solid to the cross member, and the motor is mounted solid to the K-member-thing... pull into a drive way...
The front end of the car twists while the center section does not. Now you have a tranny trying to stay in one place while the motor is twisting.
Since the motor and tranny are linked solidly together(as you pointed out) now the flex-stress is being absorbed by the bellhousing(since neither the motor mounts or tranny mount have the ability to flex on their solid mounts) Poly/rubber mounts absorb/conform during chassis to flex to allow the motor and tranny to stay linked solidly together... no cracking the bellhousing, or associated issues.
Now... if your car is caged, with thru the floor subframes and you run a SFI bell... it's likely rigid enough structure that this would not matter.
But, in a street driven whimpy subframed situation, I'd let the motor/tranny have at least one 'flexabile' mount to accomodate twisting of the chassis.
In summary,
89MustangGX said:
~With the engine and tranny directly connected together, I don't want part of it flexing~
Exactly, that is why you allow one mount to absorb flex, and keep the tranny/motor relitivly flex-stress free.
As for the ASP's, about the only flex they will accomadate is huge impact loading... ie: bad railway crossings, pot holes etc., And hopefully, they will distort before they tear out. They are not going anywhere otherwise... not at the power I'm making, or will ever make.
