WRXKiller said:i have been hearing a lot about taking out the spring isolators in lowerd cars in order to get another 1/4 inch. What exactly is the purpose of the isolators, and is it safe to take them out....if so, how hard is this to do?
~B7~ said:Does anyone have a picture of their car with the springs isolators out? I would prefer to see someone with the H&R SS w/o the spring isolators.
Thanks.
Mine is lower than Bowens' car... I have taken a picture but can't put it up. Anyone that I can send it too that can change the size of the file for me and post it?MustangLife said:Theres a isolator on the top and bottom on each spring right? Do you take both out or just one. I want about 1/2 drop in the rear of my car i have eibach sportlines. So do I take both out and be allright or just one. If just one top or bottom.
Thanks
Josh
Cool! Will be sending the PM shortly!!~B7~ said:lwkauble, I'd be happy to resize the picture(s) for you. Send me a PM with however you want to handle this through e-mail. Thanks.
pics are on their way to you!lwkauble said:Cool! Will be sending the PM shortly!!
lwkauble said:pics are on their way to you!
JuicinSmurf said:Could we have them posted here? Also, what springs are you running?
Pete
DB96GT said:They isolate NVH (noise, vibration, harshness) from the car. You could probably take them out and not notice the increseased NVH, though. Yes it's safe to take them out. It's the same difficulty as taking out your lowered springs - which are much easier to install in the car than the stock ones.
Pull the wheel off.
Disconnect the sway bar from the lower control arm.
Remove the strut.
Remove the brake caliper and hang it from somewhere.
Push down on the LCA and remove the spring, then the isolator.
Hopefully I didn't miss anything.
why on earth would you wanna do all that....just take the sway bar off then take the bolt ataching the control arm to the rear end out and drop it down.....why you would remove the brake caliper or the strut is beyond me
grussr said:I took two off of the rear once, put them back on the next day.
They definatlly make the ride harder and add a lot of noise. But it is an easy thing to try....
