I recently wasted my clutch, all the clutch pad stuff flung off on a downshift. The clutch pedel went to the floor(clutch materal jammed stuff up) and I had to yank pretty hard to get it to shift.(thought I would limp home)
I replaced clutch, pilot bearing, ground flywheel, UPR firewall cable adjuster and quad.
My problem is that I seems like the second gear syncros are bad or the pilot bearing is draging.
I can put the car in 1st with the clutch in and never have the gears grind. If I shift from 1st to 2nd the gears grind but not all the time. If I downshift from 3rd to 2nd I sometimes get the grind to.
Any other combo of shifting is great. I can start in second and never have it grind going into third.
If the pilot bearing was draging would it be grinding in all gears?
Is the input shaft supposed to come to a complete stop when the clutch pedel is pressed or will it still spin a little?
Any help would be great,
Dave
Dave
