Terminator Questions...
Discussion in 'SVT Talk' started by Calidude, Mar 29, 2009.
  1. Calidude New Member
    Jun 2, 2005
    Message Count:
    looked at an '03 Terminator ('vert) today. A few things caught me off-guard, that I wanted to check on.
    1. Was the stock/factory terminator hood fiberglass???
    The hood/fender alignment was really off & the hood paint was terrible.
    2. Is the rear end "clunk" a common issue when shifting into reverse/1st?
    3. Clutch was stiff, moreso than I expected, but sure didn't have much "feel" to it.
    Is a decent car... had a CAI kit, Bassani cat-back, pulley kit, & SCT programmer. Would've preferred a completely stock car, but the price is right... probably $4k to $6k below Blue Book. Title & CarFax are clean, tho that's no guarantee. Had more door dings & scratches than I'd like. Rear bumper got smacked, leaving two small rub marks, but the paint was spider-webbed.
    Ran good... definitely a hoot to drive, compared to a GT. The blower whine had me grinnin... Would be a good driver, but too many issues for a garage queen. Hood & bumper repaint would definitely be in order.
    any thoughts???
  2. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    It's a composite material of some type.
    Yes. In fact just taking your foot off the gas while cruising will most often result in a clunk too. There is a LOT of slack in the stock 03/04 Cobra driveline.
    Well even the stock clutch in an 03/04 is pretty stiff... Depending on how many miles are on the one you test drove it may need adjustment or replacement.
    Check for drivers side head tick, 80MPH vibe, and pulling to the right. 3 common problems with this model. Most all of this is listed in the 03/04 Cobra FAQ located as a "Sticky" at the top of the SVT Tech forum.
    How many miles and how much are they asking?
    U.M.
  3. Calidude New Member
    Jun 2, 2005
    Message Count:
    has 32k miles... priced to move at $16k. Knew about the driver's side head tick... didn't notice it when idling in the garage with the hood up.
    Had 20" Foose rims on it. Looked sharp, but not my first choice. 20s seemed a bit much, & definitely affected ride quality. But wheels could be changed. I see you can get the 10th anniversary rims for $180 each from Tire Rack. Drove fine... tho didn't get it out of the freeway, so never got above 4th gear. Wasn't familiar with the area & didn't want to get lost.
    The 10th anniversary edition red inserts were ok, but again, not my first choice.
    Ideally, would prefer a stock '04 in Redfire... which would probably run me mid $20s... which I find hard to justify at this point when you can get a leftover '08 GT for less than $20k.
    It's a nice car, at a great price... & looks great from 10 feet... just don't know if I can get past all the paint issues... I tend to be pretty fussy, when it comes to condition.
    Thanks for the info... will remember to check the FAQs FIRST next time...
  4. SVT32VDOHC waiting for the next hack atta
    Nov 23, 2001
    Message Count:
    4,412
    My 04 has none of the problems in the FAQ's. Prolly cause is only has 6,100 miles.
    The rear end clunk is from a bad rear diff bushing. They are rubber and over time, they crack. The hoods are fiberglass. The clutch is stiffer than the Ford Motorsport in my 96 Cobra and much stiffer than all the Centerforces I have had.
  5. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    Mine clunked from day one even while brand new. I even replaced the 12MM IRS bolts with the 14MM ones and it still had a lot of slop in the drive train. It's just a poor design is all.
    U.M.
  6. fromadig91 New Member
    Jul 27, 2008
    Message Count:
    96
    I'm with U.M. on this one, when I first got my cobra I thought the clunk was an issue, especially never having owned a stick before. However everything I have come across in forums says the clunk is normal and even a slight clunk when going into 2nd or 3rd is fairly common.
  7. LaserSVT black cloud overhead on a sunny day
    Jun 19, 2007
    Message Count:
    10,849
    126
    113
    Mine has the clunk too. I am gonna replace the diff bushings when I get it back to help it some but they all seem to have it.
    Mine seems the worst if I am in 6th and not tuching the gas pedal at all then go to give it some gas. I hate that sound so freakin much but not too much I can do about it. Hell, with the car in gear and the parking brake set with the car in the air you can turn the driveshaft a few degrees by hand. :nonono: Ford really dropped the ball there in the cars design.
  8. EXTRPR50 Founding Member
    Oct 7, 1998
    Message Count:
    375
    Question, would the clunk stop if the car got a solid rear transplant?
  9. LaserSVT black cloud overhead on a sunny day
    Jun 19, 2007
    Message Count:
    10,849
    126
    113
    Prolly. Without the diff moving on the IRS sub frame you dont have that solid thunk felt through the floor :shrug:
  10. SVT32VDOHC waiting for the next hack atta
    Nov 23, 2001
    Message Count:
    4,412
    That sucks. I wonder why some have the issue and some don't.
  11. LaserSVT black cloud overhead on a sunny day
    Jun 19, 2007
    Message Count:
    10,849
    126
    113
    Mine is pretty bad but my diff bushings looked pretty shot when I saw them last. If I can just getthe damn car back I can install the bushings and hopefully get rid of alot of that damn noise.
  12. jsk1020 New Member
    May 9, 2009
    Message Count:
    What years have the "clunk"
Share This Page
