traction control?
Discussion in 'SN95 4.6 Talk' started by foxforce, Jun 30, 2007.
  1. foxforce New Member
    Sep 7, 2006
    Message Count:
    canada
    i have a question for you guys i just got back from test driving an 03 gt and i noticed the traction control light was on, i tried to shut it off and it wouldn't the salesman said that the previous owner put gears in it so thats why the light stays on, is this possibly true, i'm sure lots of you have swapped gears just wondering if your trac loc still worked afterwards . thank you:shrug:
  2. SaleenGT2001 Active Member
    Jul 19, 2005
    Message Count:
    2,925
    46
    Four Oaks NC
    not true at all.
    the car has been tuned and the traction controll was disabled. thats exactly how my car is
  3. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,644
    36
    UCSD/La Jolla
    another genius salesman
    wheres the tally we have going?
  4. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,644
    78
    Massachusetts
    Is the ABS light on??
    If the ABS light is on, then there is a problem with the system. As a default, the T/C is turned off with the ABS since it relys on the ABS sensors.
    If your ABS light comes on and then turns off when you start the engine, then the ABS is functioning.
    It's possible the PO had the T/C permanently disabled with a tuner. You would then need one to turn it back on.
  5. SaleenGT2001 Active Member
    Jul 19, 2005
    Message Count:
    2,925
    46
    Four Oaks NC
    why would you want it on??? our TCS sucks!!!
    i have my TCS off, no ABS and the ERG deleted.
  6. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,644
    78
    Massachusetts
    To each his own on the ABS and T/C....but why did you delete the EGR?
  7. SaleenGT2001 Active Member
    Jul 19, 2005
    Message Count:
    2,925
    46
    Four Oaks NC
    i wont be running it when the new engine goes in, so when it got tuned a few weeks back we just took it off.
Share This Page
