Tuning!!!
Discussion in 'Fox 5.0 Tuning' started by 92NOTCHJONZY2, Nov 16, 2009.
  1. 92NOTCHJONZY2 New Member
    Nov 15, 2009
    Message Count:
    NEBRASKA
    I have never tuned a 5.0 before personally i have seen it done but i have a few ?s on it, should i run a mega squirt system? what should i do for my fuel system to make it run correctly i have fuel pressure reg. aftermarket injectors and quite a few mods done to my car, motor ran aweosome i just want it to scream when i drop it back in!!!!!! any tips or tricks out there?
  2. tannerc91gt Advanced Member
    Mar 29, 2009
    Message Count:
    3,933
    18
    68
    Indiana
    You're going to need to list your setup. MSII had a very steep learning curve if your unfamiliar with it. Without knowing your setup, i'll still say a dyno tune will be less expensive, easier and they'll burn you the chip you need
  3. 92NOTCHJONZY2 New Member
    Nov 15, 2009
    Message Count:
    NEBRASKA
    ok thanks i was leaning toward a dyno tune
  4. ddonaca351 Active Member
    Dec 1, 2002
    Message Count:
    2,072
    48
    Camas Washington
    (imho)
    A dyno tune is always the best way to go, if you're tuning it yourself or paying a tuner to do it... it's best to have it done on a dyno. It gives you the ability to simulate conditions, apply loads as desired, etc... actual conditions as required by the comp, not just "educated" guess as done by seat of the pants.
    Always save the extra bucks and get some dyno time.
    (again just mho)
    :nice:
  5. BlownFiveLiter have car, will race....wait, it doesn't run
    Oct 23, 2004
    Message Count:
    5,448
    88
    Chicagoland
    What setup are you looking to tune? The stock EEC is very capable, so there's really no reason to reinvent the wheel and look to an aftermarket setup with a mild setup.
  6. 92NOTCHJONZY2 New Member
    Nov 15, 2009
    Message Count:
    NEBRASKA
    i got 24lb inj, f303 cam, stock heads with a valve and bowel job, edelbrock 65mm throtle body, mass air sensor, edelbrock upper and lower intake, gear drive, 1.60 roller rockers, bbk longtube headers, x pipe, 10 series flowmasters, with a tko 500 aluminum flywheel, centerforce clutch, msd 6al,blaster coil, my a/c and smog is pulled and bypassed, if there is any ideas or tricks out there i am open to them, i want it to be streetable but yet fast, it also has 4.10 gears
Share This Page
