01LaserRedCobra
- Feb 20, 2002
- 318
- 0
- 16
I had that exact same problem with mine, but I had QA1 struts. They were the biggest pieces of crap and one, busted on me. I got Bilstein the second go round which is what I should of done to begin with. I think the noise is coming from the spacers, cause you can't tighten the nut on the strut tower real tight. Like 80ftlbs. which makes the spacer knock when you hit a bump. The Bilsteing have a hex opening at top which made it easier to really tighten down. I have no more knock over the potholes and man hole covers or train tracks. Also it helps to tighten the strut tower nut with the spring and strut under load. Place a jack under the lower control arm and jack it up as far as you can.
These tips may not be agreed on by everyone, but these are some things I did. That noise used to drive me crazy, but everything is cool now.
