Variation in Ride Height
Discussion in '2005 - 2009 Specific Tech' started by JTGrant, Oct 15, 2007.
  1. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    I have the FORD service manual CD's, but I couldn't find any specs on factory ride hieght or variance. I measured from the bottom lip of the wheel to the arch on the wheel housing. In the front there is an 8mm difference from the left side to the right side. In the rear the difference is 10mm. Could some of you guys measure and see what the variance is on your car? I would really appreciate it. Also if anyone needs any documents or specs of any kind I have the Ford CDs from 2002 to 2008. THANKS!
  2. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    Would someone please measure their car.
  3. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    do you want only stock cars? mine is lowered, so i dont know if that would help you out any.
  4. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    Pretty much the only part that affects ride height is the spring. I plain on buying the Ford Racing M-5300-K very soon. Sure bigcat measurement of modded suspension ride height variance would be great. Thanks
  5. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    ill measure in the morning, when there is light.
  6. 281Ponies New Member
    Nov 14, 2003
    Message Count:
    190
    I'm running the same spring if I can get the car up in the shop... level surface tomorrow I'll check mine.
  7. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    I just ordered the Ford Racing K springs from americanmuscle.com for 219.00 shipped.
  8. 281Ponies New Member
    Nov 14, 2003
    Message Count:
    190
    Just pulled the car in for a quick measurement. Measured like you did from the bottom lip of the rim up...
    Front Driver side - 23 1/2"
    Front Passenger side - 23 1/2"
    Rear Driver side - 24"
    Rear Passenger side - 24"
    Also measured from the wheel center up...
    Front Driver side - 14 1/2"
    Front Passenger side - 14 1/2"
    Rear Driver side - 15"
    Rear Passenger side - 15"
  9. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    Thanks 281ponies, would someone please measure their Mustang with stock suspension?
  10. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    The only thing that I can come up with is that there is a problem with the springs on the car.
  11. infinityonhigh New Member
    Aug 15, 2007
    Message Count:
    Nothing is wrong with your springs, its normal. There are more components on one side of the car than the other which adds up to a greater weight biased on one side of the car (hence the "lean"). Plus 8 to 10 millimeters is really not that much it's more like splitting hairs. I guarantee you that your new springs will do the same thing. Thats just the way these cars are built. No worries.
  12. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    I realize that, but 10mm is a good bit of a difference. Cars these days are built to tighter standards. I found the Ford procedure for measuring ride height, lets just say its bass ackwards. There shouldn't that much of a difference in ride height 10mm is around a 1/2 or so (.4 tenths of an inch). I guess measuring BMWs all the time before doing an alignment has made me this way. Our ride height tolerance is very tight. Yes I realize that I talking about a BMW and not a Ford, but come on. Fords are nice too, the cars does have 40,000 miles on it. I guess I will find out when I install the new springs.
  13. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    Come on will some of you guys check you cars? Please.
  14. Frank S New Member
    Jun 26, 2007
    Message Count:
    54
    I measured the ride height of my stock V6 before and after installing Steeda Sport springs.
    Left side was .35 inches lower than right in front, .15 inches lower in the rear.
    Same result with the new springs "settled in".
  15. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    Frank S thank you for taking the time to do that for me.
  16. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    from lower wheel lip to top of wheel opening.
    LF: 610mm RF: 607mm
    LR: 623mm RR: 625mm
  17. stangdude2000 Founding Member
    Jun 24, 2001
    Message Count:
    1,736
    Northern VA
    I have stock suspension, but I won't be home until Saturday afternoon, at which point I will try to remember to check.
    Everyone's ride height will be different with different options. You also should not measure from any point on the wheel. Measure from level ground. Measuring from the wheel would cause slight differences in ride height because of slight differences in tire pressure. Also, if the car isn't on perfectly level ground, it will unquestionably lean to one side. Before you get too concerned about 10mm (less than half an inch), make sure none of these factors could be effecting it.
  18. JTGrant New Member
    Aug 3, 2005
    Message Count:
    776
    GA
    THIS IS WHY YOU CHECK THE TIRE PRESSURE BEFORE YOU CHECK RIDE HEIGHT. Look at almost every macfacturers procedure before an alignment. The usual measurement is from the bottom of the wheel to the arch on the wheel well. There are a few other places to check ride height, but this is usually the quickest and easiest way before an alignment. It is accurate. I made sure that there were no other factors in my measurement. I even measured the car on the alignment rack, which is level. I also measured from the top of the strut to the bottom of the control arm (with the wheels off and the car was on the lift) both sides were even. So it looks like the problem lies with the spring, which I figured anyway becuase that is what determines your right height. I was just wanted some of you guys to check your cars, because I couldn't find a spec on the FORD TECH cds that I have. I wanted to see what variance there was in other S197 Mustangs. 10mm isn't very much, but my car was wrecked about 3 weeks ago. The only damage was to the body and bumper. No fram damage at all, I however notice that after the wreck the toe was out of adjustment. I was driving down the road (3 lanes), I was in the 3rd lane. All of a sudden some ahole decided that he was going to cross 3 lanes of traffic to pull into Arby's. He came out of nowhere, I had just enough time to hit the brakes. I T-boned him doing about 30 mph. Luckily I hit his truck (S10 work truck) between the B and A-pillar. So I hit the soft spot of the truck. No one was injured, the Cop cited him with failure to yield while crossing a roadway. I just got the car back from the body shop. They did a great job, you can't tell that it was wrecked. The total damage was 4,200.00. BIGCAT this is why I decided to not sale the car. I never measured ride height before the car was wrecked, I just wanted to make sure.
  19. kawzx7 New Member
    Jan 8, 2002
    Message Count:
    14
    So, how can this be fixed?
    I was thinking of cutting 1/2 a coil out of my springs to fix the disparity. Any thoughts?
  20. MikeysOTP New Member
    Mar 30, 2007
    Message Count:
    206
    Is this just a case of the springs wearing more on one side than the other from driver weight, equipment, etc.? If so can't you just switch the springs from one side to the other? They should even themselves out if that is the case.
Share This Page
