Hi,
I just recently started having issues with my 95 Vert. If I drive the car for about a 1/2 hour and get it nice and warm, then shut the car off and try and restart it with in 15 minutes the car won't start. The car cranks fine, i have spark and I can hear the fuel pump prime. Last time this happened I depressed the shrader valve on the fuel rail to see if there was any fuel in it. Instead of fuel coming out I got air coming past the valve, then fuel. Once I had a steady fuel flow I was able to start the car. The time before that I just let the car sit for 2 hours and it started up. It seems as if I have a vapor lock problem? Any ideas?
The car is not showing any codes, I'm thinking that I either have a failing fuel pump, pressure regulator, or a leaky fuel line. What do you guys think?
Thanks,
Mario
Thanks,
Mario
