washed engine,now problems
Discussion in '94-95 Tech' started by davis3, Nov 12, 2009.
  1. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    ok,i washed the engine this past weekend.
    i removed the alt and upper intake to reloom the wires.
    blocked off intake ports,plugged pcv valve,removed plug wires.
    then sprayed engine with degreaser,let soak,washed off.
    blowed dry with leaf blower,let dry.
    i washed upper intake seperatly,also washed plug wires.
    towel dried.
    these got wet,coil,icm and dizzy.
    i removed cap and there was alittle water in dizzy,i dried it.
    i reassembled everything,the car started right up.
    drove home fine.
    next morning,starts up fine.
    but,before fully hot,car will not accelerate.
    at around 2k,it stutters and refuses to accelerate.
    around 3k,it takes off,pulls hard.
    will do this for the first 5(?)minutes.
    after this it will run fine.
    i pulled the cap again,no water.
    i used an alcohol pad to clean the pip,checked for jumping spark(none).
    today,the check engine light came on while driving after sitting all night.also has the same symptoms until up to operating temp.
    i have not pulled codes yet,reader is at the garage.
    i will check in the morning.
    if anyone can help me out,i would greatly appreciate it.
    :SNSign:
  2. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,855
    78
    Harvey, nothing jumps out at me. You took care of the dizzy, which is the biggie. The coil and TFI module are designed to get wet.
    Is there any chance something else is going on (a connector was left undone or came loose)? Maybe the code will narrow it down......
    Good luck brah.
  3. Adam95GT New Member
    Aug 14, 2006
    Message Count:
    2,600
    Burlington, NJ
    im thinking 02's...:shrug:
  4. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    Posted via Mobile Device
    thanks guys.
    fwiw,its an msd coil.
    i'll go through all the connections again.
    and pull codes.
    i'll report back later.
  5. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    177-hege sensor fault/always rich.
    543-fuel pump secondary circuit fault.
  6. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
  7. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    grease at all connections.
    also cleaned the pip again.looked like it had some rust on it.
    used the connector cleaner on a clean rag.wiped off alittle red.
    after,passed
  8. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    koeo,and koer tests.
    also threw on my stock coil.
  9. BlackVert Mustang Master
    Oct 3, 2003
    Message Count:
    5,595
    78
    Bethesda, MD
    "177-hego sensor always rich" sounds like a winner to me.
    :nice: nice call adam
  10. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    what can lead to a 177?
    did not soak the engine.
  11. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    after letting the car sit for about 30mins,same problem.
    after about 3mins of driving,it clears up.
    should i be looking for bad wiring or at a bad o2?
    dont have time to really look til the weekend.
  12. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    thanks everyone for your suggestions/comments.
    please keep them coming.
  13. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    chilton's says 177-hego shows system always lean(left)
    i'll check readings tomorrow.
  14. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,855
    78
    As noted above, 177 is a rich (lean adaptive limit) code as I recall.
  15. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    just a little more info.
    -the car starts fine.
    -will idle til the cows come home,on cold engine and hot.
    -runs good warm,i let it idle for 5 mins before coming home tonight from work.
    no check engine light,accelerates good,a little rough though.
    -the hpipe took a hard hit holloween night,on passanger side.
    me and my girl were on our way to the strip club:)banana:),
    there was a big chunk of concrete in the road i was unable to avoid.
    put a dent in the pass side tube and split apart the crossover.
    i had it clamped togeather,and a couple spot welds so it would not vibrate loose.
    i pulled it out the next morning and completly welded it togeather.
    but the car ran fine until i washed the engine last sunday.
  16. nmcgrawj Advanced Member
    Sep 28, 2003
    Message Count:
    3,674
    66
    Indianapolis, IN
    I've never had that code....
    but my first guess is you need a new o2 sensor. :shrug:
  17. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    me neither.
    i'm going to check the o2 and wiring today.
  18. nmcgrawj Advanced Member
    Sep 28, 2003
    Message Count:
    3,674
    66
    Indianapolis, IN
    They do go bad though....and i dont think thats always by visual inspection.
  19. davis3 Member
    May 7, 2006
    Message Count:
    936
    18
    fresno,ca
    waiting for the o2 sensor to cool so i can check it.
    thing i noticed though,is when i wiggle the wires at the base of the o2,on the driver side,i can hear a slight scraping sound.
  20. Bullitt95 Active Member
    Jun 13, 2007
    Message Count:
    1,060
    38
    Al Ain, United Arab Emirates
    That chunk of concrete might have damaged the O2 sensor or the wiring to it.
    Could be just a coincidence.
Share This Page
