Ok, just came inside and cant get the damn the running.Itook the heads off and put them back on -dont ask why Im a dumb#@$ and while I was in there changed the injectors to 24lbs and gat a C+L 76mm intake system with mass air for the injectors. I fired it up and cant get it to run right. It will only idle when the timing is retarded. I warm it up to get the light on it to advance it to say 10BTDC for a reference and it dies before I can get even close. It will only idle at 10ATDC. Fuel pressure is at 38lbs which was the last setting I had. Any ideas?? Is it too much fuel?? Im so pissed I cant think straight.Thanks.
