You should dial in the bellhousing anytime you get a different one or put the same one on a different motor. All you need is a dial indicator with a magnetic base. Put the base on the end of the crank with the indicator reading from the edge of the bellhousing hole. Start at 12:00 and rotate the motor 360 degrees. I usually take readings at 12,3,6 & 9. Do the math and figure out which way it needs to go, if any. What your checking is to ensure the centerline of the crankshaft is aligned with the centerline of the transmission input shaft. I think factory spec is around .003". Not positive on that though.
