Which hits harder/better, two 10's or one 12?
Discussion in 'Mustang Sound & Shine All' started by BullittStangV8, Jan 4, 2004.
  1. Nottoofast50 Founding Member
    Dec 9, 2000
    Message Count:
    389
    Cali
    Oh and bbrinks just curious why do you need a subsonic filter with a ported box and the jbl amp? I dont have one on mine...
  2. BullittStangV8 Founding Member
    Oct 5, 2002
    Message Count:
    1,105
    36
    NJ
    okay i was looking at ikesound.com, the prices are pretty darn good. i have the cash to buy 2 12' type R's, and either the 1200.1 or the 600 jbl amp. do i need 1200 for two type r's? or can the 600 handle it? also, where can i find a good ported box for it? local circuit city or someplace? also will i need a capasitor to hold the power?
    Mike
  3. ryanrule impotent
    Feb 11, 2002
    Message Count:
    1,437
    Madison, WI
    ide get the 1200, type r's like power. ide recoomend u find someone to build a box for u it u dont wanna do it yurself, custom is better
  4. BBrinks Founding Member
    Sep 26, 2002
    Message Count:
    519
    Woodridge, IL
    For the ssf, It depends what frequency your box is tuned at. Below the tuning freq., the sub unloads. If it's tuned pretty low, it's not as big a deal, but if it's tuned at say 40Hz or so, you risk damaging the driver if you play test tones through it.
    As for the amp, the JBL's usually are underrated, so the 600.1 should be fine. I've heard some guys running them with 750 RMS, but 300 watts should be fine, especially if they're ported.
    If I were you, I'd build the box yourself, but you can find a stereo shop, they'll usually build one for you. Check out http://www.woodlawncabinetry.com/ He posts on caraudioforum.com and a lot of guys over there have gone through him. He makes great boxes and everybody over there is very happy with the results. His name is Phil and his screenname is MrCabinetry. Just ask him for a quote.
    I wouldn't bother with a cap. Just upgrade the "magic three". Changing the wires from: battery + to alternator, Batt - to ground, and engine block to ground to 2 guage should solve any dimming problems you might encounter. With the 600.1, you should be fine, it won't put too much strain on the electrical system.
  5. BullittStangV8 Founding Member
    Oct 5, 2002
    Message Count:
    1,105
    36
    NJ
    okay well right now it seems as if ill be going with 2 12'alpine Type R's. I still dont know if the 1200.1 is needed over the 600, but if i have enough cash i might be able to go with the 1200 anyways. Also, i still need advice on ported vs. sealed. i listen to both rap and rock, but i usually turn the bass down to half way when listening to rock. (too much bass with rock doesnt appeal to me) also, how much volume will i need with a ported and sealed box?
    Thanks guys, you're really helping me out!
    Mike
  6. BBrinks Founding Member
    Sep 26, 2002
    Message Count:
    519
    Woodridge, IL
    I can't remember off the top of my head for the ported, but I think about 1 cu. ft. or a little more like 1.2 sealed would work. I'll try to find the ported size and tuning freq. on my other computer. If you ran 600 watts to each in a sealed, it'll be more than enough bass for what type of music you listen to. delvryboy on caraudioforum ran the same combo and he said it sounded great, but I think he might use Resonant Engineering stuff now.
    If you want to get the 1200.1, you could use the dual 4ohm versions of the type-r and wire them in series-parallel to give you a 4ohm load on the amp. This'll give them 300 watts each, and if you think that it's not enough for you, just wire them parallel-parallel to give a 1ohm load on the amp and give them 600 watts each. BTW, the amp is 1ohm stable, and it doesn't give any more power if it's run at 1ohm or 2ohms. Check this site out for wiring options if you don't know already: http://www.jlaudio.com/tutorials/wiring/index.html#2dvcpp
    Hope this helps some. I'll try to dig up some info on the ported box for you. Type-R's can sound good in a ported box, but they're great in a small sealed box with a lot of power.
  7. BBrinks Founding Member
    Sep 26, 2002
    Message Count:
    519
    Woodridge, IL
    I totally forgot, if you want another suggestion on a sub, these are the subs I plan on getting: http://www.woofersetc.com/product.asp?0=416&1=421&3=2185 They'll take 600 watts easy. I'm installing one 12" in my friend's s10 when he gets his amp. I was actually going to run the type-r's before I decided on PG. He got his ti12D for $79 somewhere, but I can't remember if it was woofersetc.com during their sale or not. They're great SQ woofers, and they'd sound great in a small sealed box. Not too many people run them, also. They used to retail for over 300, but I think they're being discontinued by PG. Just something else to look into. I think those subs paired with the 1200.1 would be a great setup.
  8. BullittStangV8 Founding Member
    Oct 5, 2002
    Message Count:
    1,105
    36
    NJ
    thanks for looking up the sealed box and ported sizes. that helps allot. btw when you say a small sealed box, do you mean that the box is very close to the suggested/required volume rather then larger then the suggested volume?
    Mike
    p.s how much are my two impp 10 inch subs, in a sealed box, and the pioneer 400 watt amp worth? (model number posted above in a post) some kid i know wants them, and hes got deep pockets, and doenst know anythin about subs :nice: so i might be able to get a few extra bucks off of him. :rolleyes: how much should i sell them to him for?
  9. BBrinks Founding Member
    Sep 26, 2002
    Message Count:
    519
    Woodridge, IL
    If you're going to run a lot of power to them, the bigger the box, the less the power handling of the sub. They perform well in the recommended size enclosure. For the ported size for the type-R, I think it's around 1.5-1.75 cu. ft. tuned to around 35 or 40Hz. Might be a lower tuning freq, though, I think that might be for the 10".
    As for selling the subs, they're selling on ebay for about 40 each, so try somewhere around there. For the amp, they're about 130 or so new, so as for like 60 bucks or so for it. Up to you really. I remember a long time ago before I knew better, my friend sold some subs like this: http://nexxon.com/funkypup/funkypup.htm in a piece of crap box to me for like $120. He probably knew he was screwing me over, but I didn't know until later that they were junk. If you haven't abused them, he's getting pretty good equipment. If he get's a new amp for the subs later, that amp would be perfect for a pair of components.
    Bill
  10. BullittStangV8 Founding Member
    Oct 5, 2002
    Message Count:
    1,105
    36
    NJ
    okay thanks for the prices, ill ask him today about it today. this kids not exactly a friend of mine, so taking a few extra bucks off him wounldnt make me feel terrible..lol okay so hows this for a final set up: 2 alpine 12 inch type R's in a sealed box, with the 600 amp jbl amp? btw whats the volume for a sealed box with these subs?
    thanks
    Mike
  11. BullittStangV8 Founding Member
    Oct 5, 2002
    Message Count:
    1,105
    36
    NJ
    ttt. im almost set on what im getting, i just need to know if the 600 watt jbl amp will be enough to fully power 2 12' alpine type r's?
  12. BBrinks Founding Member
    Sep 26, 2002
    Message Count:
    519
    Woodridge, IL
    Sorry, been busy last couple of days. That amp should be fine for the subs. If it's not loud enough, you could always port it. If you're running a basically stock system except for the subs, it'll definetly be loud enough for you.
  13. BullittStangV8 Founding Member
    Oct 5, 2002
    Message Count:
    1,105
    36
    NJ
    no need to appologize bbrinks. i appreciate all the help that you have given me. ill let you guys know what i finally end up doing.
    Mike
    p.s last question, is www.ikesound.com a legit and good place to order the equipment from? i dont want to get scammed.
  14. BBrinks Founding Member
    Sep 26, 2002
    Message Count:
    519
    Woodridge, IL
    If you want to get the amp, I'd recommend going through sounddomain.com. Just contact them about price matching ikesound's price. They price match their stuff and they're an authorized JBL dealer, so they carry JBL's warranty, unlike ikesound.
    Ikesound's not bad to go through, they just don't carry some companies warranties.
    Glad I could help, and hope everything works out for you.
    Bill
  15. BullittStangV8 Founding Member
    Oct 5, 2002
    Message Count:
    1,105
    36
    NJ
    okay seems like this is the right amp: http://www.sounddomain.com/sku/JBLBP6001
    JBL PowerValve BP-600.1 Subwoofer Mono Amp
    sound domain has it for i belive about 260. hopefully ill be able to shave off a few extra dollars by matching it with ikesound.com
    Mike
Share This Page
