WHY!!!!!!!!!!!!!!!!!
Discussion in '2.3L (N/A & Turbo)' started by robbo1987*2.3*, Oct 16, 2009.
  1. robbo1987*2.3* Founding Member
    Apr 22, 2002
    Message Count:
    436
    this is the second time this has happened to my motor. # 2 piston is missing a big chunk wtf???!!! this is th second time this has happened to me im using all stock turbo bottom end parts only thing done to the motor is head studs, cometic m.l.s. thats been retorqued 4 times or added assurance lol, i blew my t3 out and stuc an ihi on it for he time being actually scheduled to get the t3 back tody fro the shop lol go figure, light port work on the entire topend.
    i know these motors are tuff from the factory as far as the bottom end goes why does it keep chunking pistons??????? 15 lbs of boost daily driven street car that has be lw 13 i dunno imma fix it because i love my carn all but im just wonderin whats the deal with the pistons?????
    n e 1 eles ever had this problem just wondering
    robbo
  2. Flyin2.3 New Member
    Sep 12, 2009
    Message Count:
    30
    Sounds like detonation to me. 15# really isn't a lot of boost if you have an intercooler but something is causing it.
    Broken off out by the rings? Any speckles on the spark plugs? Whats your timing set at? Fuel octane rating? Have an IC? What computer/VAM/injectors? Turbo or n/a head? Any more info would be helpfull.
  3. robbo1987*2.3* Founding Member
    Apr 22, 2002
    Message Count:
    436
    yup
    they keep peeling up the top ringland/guide whatever you wanna call it right against the cylinder wall. Its all good tho got a fresh longblock with my t3 that i got back they put 360degree thrust bearings in it with upgraded wheels from and back. a 3 inch down pipe that has the 5 bolt flange made into ito it( not a stock neck cut and reworked it came off a precision that was mounted in a 2.3 turbo stang on a stock e6 its purdy lol)
    the head has the roller cam with light port work but stock valves, a set of 42 lb injectors, a 150lph pump ajustable regulator. but all stock ecu and im still running the vam. volvo front mount also
    imma take it to my tuner guy he said that he can work with the setup that i have he is a well known guy in richmond the call him mike he drives a saleen notch that has a turbo 32 valve cobra motor stuffed in it i can remember his website of teh top of my head though ill find it and post it up he does really good work thats what matters to me lol ne ways i will keep you guys posted on what happes with it all later
    robbo
  4. Flyin2.3 New Member
    Sep 12, 2009
    Message Count:
    30
    The only thing I see that stands out is the fuel pump. 150lph seems a bit small, most run a 255lph high pressure pump. That could easily be causing a lean condition/detonation.
  5. turboeeyore New Member
    Oct 25, 2001
    Message Count:
    the 150lph is fine, 255 is big enough for a supercharged v8, the 150 is the upgrade most grand nationals use. were these forged pistons in this car? if so could it be possible that #2 injector was faulty too much or not enough fuel?
  6. robbo1987*2.3* Founding Member
    Apr 22, 2002
    Message Count:
    436
    not really
    it didnt show any signs of a lean condition i had had the shortblock in the car for almost 3 1/2 years and i beat on it relentlesly day in and day out. I got it out of the junkyard for 60 bucks. Yes it had the factory forged pistons in it it came out of a 88 turbocoupe.
    the new setup is now a fresh longblock with light port work on the head,gutted upper and knife edged lower gasket matched to the head, stock valves, 93 mustang roller cam, 42 lb injectors,highly ported e6, rebuilt t3 has 360' thrustbearings and upgraded wheels front and back, 3 inch turndown with full 3inch exaughst to the axle with a dump, arp headstuds, commetic mls headgasket, 155lph pump
    on 8 lbs it runs great
    anything else it runs good till you get in the upper rpms around 4 grand its starts leanin out real bad, dont know what my fuel pressure is. i got a fpr and pressure guage to put on it so for now i just run it at 8 lbs till i get around to fixing it. 8lbs on this setup feels like 15 lbs with the old ihi setup. The car deffinately has high 12 second potential, fastest with the old setup was a 13.7 at 101mph( ragged out t3 ) anyways enough rambling
    robbo
  7. wicked93gs New Member
    Sep 30, 2006
    Message Count:
    565
    you say its a 15lph pump...the question is is...when was it last replaced? the stock pump is notorious for being junk and not flowing well after about 10 years or so...replace it with a Walbro 255...mine also runs well up to about 12psi...where it starts breaking up...its either the regulator, the pump, or timing...mine has a MSD coil and possibly a MSD TFI module(cant really see to tell)...I've been considering replacing that stuff with stock stuff(dont really trust MSD stuff from prevous bad experiences) another suggested buy...a wideband...I'll be doing both these myself within the next couple of months o I can see whats really going on
  8. Dr_EluSivE Founding Member
    Apr 24, 2002
    Message Count:
    2,387
    56
    Fuel pump or injector for that Cyl. i would swap all the injectors out, or atleast that one and see if it helps.
    Dr.
Share This Page
