Wire confusion
Discussion in 'Mustang II' started by myfirstii, Oct 6, 2004.
  1. myfirstii Founding Member
    Feb 28, 2002
    Message Count:
    401
    Im finished putting my motor together and im a little confused as to what wire goes were on the starter relay. Can some one take a pic or draw me a diagram. Also I put on some AFR aluminum heads and i was wonding if i can still ground the negative baterry cable there?? If not, where else can i put it.
    Thanks,
    Pat
  2. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    I wouldn't ground to alunimum unless I had to.
    High amperage through a three dissimular metals junction is asking for corrosion of several types and thus a high resistance connection. There are treatments and gels/ inhibiters that can be used, Sleeper can give better information on these than I.
    There is a bolt on the forward right of the lower block that begs to be used as a ground.
  3. Mstng2 Founding Member
    Jun 27, 2002
    Message Count:
    789
    18
    not the best pics but the small push on wire goes to the "R" terminal on the relay. of course pos goes on side closest to Battery and other side also pos, goes down to starter. The ground you can move to one of the bell housing tranny bolts. Hope that helps.
    [IMG]
    [IMG]
  4. myfirstii Founding Member
    Feb 28, 2002
    Message Count:
    401
    Thanks alot for the replys guys. Im pretty sure i have it all hooked up right, but for some reason im still haveing a problem. When i go to start it all it does is make a clicking noise that comes from the starter relay. I know that its not a bad starter relay cause its brand new. Also i have a new mini starter....am i suppose to wire some thing different because of this \. What am i missing. Anyhelp would be great.
    Thanks
    Pat
  5. zwhitr Founding Member
    Aug 27, 2001
    Message Count:
    851
  6. myfirstii Founding Member
    Feb 28, 2002
    Message Count:
    401
    Thanks zwhitr.....the diagram shows two wires going to the starter from the relay why is that??? Ihave one going to the relay from the + battery cable and then a wire going from the other side of the relay to the starter. Man i hate wiring
    Pat
  7. cobraii351 Founding Member
    Jan 10, 2000
    Message Count:
    1,096
    36
    With the ground you are better off going straight to the block. With the PMGR starter you need two wires going to it as it has a solenoid on it like the GM starters do. You need the 1 heavy wire for the main power and 1 smaller wire to trigger the solenoid on the starter. The diagram shown is the best way to wire it. The second wire doesn't have to be too big I think I ran a piece of 14AWG and zip strapped it to the larger wire.
Share This Page
