Went out yesterday to drive the convertible...nice day for it. I drive it around town for a while and come back. I go back out 10 minutes later and the car barely turns over. It's like it's struggling to turn over. I look up and see black smoke coming out the right front of the grill. Right where the battery is suppose to be. Look at the battery and there are two ground wires. One VERY thick one for the ground to the block coming off the negative terminal. And a small thinner one coming of the negative going to a screw near the headlight. The insulation on the small thinner one had melted and it was fused to the battery. I pull it off the battery and you can see exposed wire. After that the car started right up with no problem.
Not sure if the gauge of the smaller wire was thick enough. I looked at it further today and it looked a little burnt. Shouldn't be a problem replacing it however I'd like to know what might have caused this.
I can see where it is very easy for that wire to sag and make contact with the battery. Is it possible the battery got hot enough to melt that wire ? If so that's a simple fix. Not sure what the other problem could be unless the wire was just old. It was there from the previous owner.
I will confess I haven't looked at a wiring diagram yet to see what this is connected to.
