i am very interested to know if the extreme can actually beat the the shelby...the conversation stalled b/c someone mentioned price....but the shelby is being solded at the dealers in orlando for 74,000....so the conversation is legitimit again. So which is faster? does anyone have an extreme? or a shelby?
I asked this question a while back and a quick look at the performance specs off Saleen's website shows a LOT of modifications for the Extreme. We're talking balanced aluminum driveshaft, flywheel, forged internals, 15 inch disk brakes, and no speed limiter (I think the Shelby has one..)
Stock for stock, the Extreme is more powerful (more HP plans on alternative tunes for 07 bumping 600hp), and the car is published as being lighter, although I don't know how that happened...
FYI - below is some of the E mods:
Curb Weight, lb. est 3356
Weight Distribution, F/R 53/47
Fuel Capacity, gal. 15.7
Wheelbase, in. 107.1
Track, F/R 62.8/63.9
Width 74
Length 189.1
Height 56
Trunk Space, cubic ft. 13.1
ENGINE
Type 4.6L, 3V, SOHC V-8
Bore and Stroke 3.55 x 3.54 in.
Displacement 4.6 liters, 281 cu in.
Crankshaft Special Saleen Forged Steel
Connecting Rods Saleen Forged Steel
Pistons Saleen Forged Aluminum
Exhaust System Saleen Stainless, 2.5 in. Variable Exhaust
Horsepower 550 bhp @ 6100 RPM
Torque 525 lbs-ft Torque @ 4900 RPM
Fuel Premium Unleaded 91 Octane
Saleen Intercooled Supercharger Saleen Series VI Integrated TwinScrew Supercharger With Two-Stage Water-to-Air Intercooler System; Cast 356-T6 Aluminum Alloy Construction
Radiator Saleen Performance dual-core radiator and high flow cooling system
Calibration Saleen PowerFlash™ performance calibration
Intake Saleen Design Hi-Flow Inlet Tube and Air Box
Fuel Injectors 39 lbs.
Mass Airflow Sensor 98mm
DRIVETRAIN
Transmission Saleen Quick Ratio 6-Speed Transmission
Differential Saleen 4.10:1 Maxgrip™ Differential
Clutch High performance clutch
Flywheel Light Weight Aluminum
Driveshaft Balanced Aluminum
AIR MANAGEMENT DESIGN
Saleen Aluminum Hood w/ Heat Ventilation
Saleen Design Injection Molded TPO Front Facia
Saleen Carbon Fiber Front Splitter
Saleen Front Aero Ducting
Saleen Design Injection Molded TPO Side Skirts and Door Cladding
Saleen Design Injection Molded TPO Rear Facia
Saleen Carbon Fiber Rear Diffuser
Saleen Design Front Grille
Saleen Integrated Front Turn Signals
Saleen Center Body Panels (rear)
Saleen Design Rear Spoiler and End Caps
Saleen High Intensity Headlamps (HID)
Saleen Designed Quarter Window Trim Optional
This Saleen designed quarter window panel gives the S281 “Extreme” a unique race inspired profile by adding a body colored panel on the outside of the quarter window as well as a Saleen branded black-out panel on the inside.
Saleen Scenic Roof Optional
Extend your driving pleasure with the installation of a high quality tempered glass roof. The structurally sound glass roof is tinted and has been tested to meet all federal safety requirements. This option completely replaces the roof of your coupe and
SUSPENSION
Springs Saleen specific rate front and rear springs
Struts Saleen front struts (N2)
Shocks Saleen rear shocks (N2)
Control arms Boxed
lower control arms
Axle Three link live rear axle
panhard rod
Front MacPherson strut with lower control arm;
Saleen Racecraft system including N2
struts with linear-rate coil-over springs;
1.38-in. tubular stabilizer (anti-roll) bar
with urethane pivot bushings; specially
calibrated
suspension settings
Rear Live axle located by three links plus
a
Panhard rod; Saleen Racecraft
system including direct-acting,
linear-rate coil spings and N2 shocks;
0.79-in. stabilizer (anti-roll) bar; specially
calibrated
suspension settings
Chuck
